The EVE chip has a number of built in fonts. You can access them directly using the "cmd_text" command. I've added a new basic command in addition to the PRINT command - "GDPRINT"
You can specify the font (#16-31), cursor position and colour, plus a string to be displayed on the screen rather than the console.
5 CLS $FFFFFF: CLR
10 SIZE 16
20 CURSOR 60,60
30 GDPRINT"HELLO WORLD!"
35 GDSWAP
40 PRINT"DONE"
This produces black text in the top left of a white screen.
This was quite a fiddly change to make. The EVE text command needs a lot of parameters both strings and numbers - so I broke it down into multiple basic commands. Size & Cursor just add the data to the stack and GDPRINT sends everything to EVE. EhBasic interprets the line and gives you a pointer to the string and the length of the string. Passing them to 'C' means I need to cast the string pointer as a uintptr_t and then copy it to an initialised buffer.
LAB_GDPRINT MOVEM.L A0-A2/D0-D7,-(A7) * Save working registers BSR LAB_EVEX * evaluate expression BSR LAB_GBYT * scan memory BNE LAB_SNER * if not [EOL] or [EOS] do syntax error and * warm start MOVE.l (a4)+,gfxText(a3) * string address from descriptor stack MOVE.w (a4)+,gfxTextLen(a3) * string length from descriptor stack pea gfxTextLen(a3) pea gfxText(a3) pea lineColor(a3) pea lineSize(a3) pea y1(a3) pea x1(a3) jsr gd_text add #24,sp MOVEM.L (A7)+,A0-A2/D0-D7 * Restore working registers rts
void gd_text(uint32_t *x, uint32_t *y, uint32_t *font, uint32_t *color, uint32_t *text, uint32_t *len)
char string[256] = {0};
uint8_t lenb = (uint8_t)((*len >> 16) & 0xff);
uintptr_t ptr = (uintptr_t)*text;
volatile char *buf = (char *)ptr;
for (int i = 0; i < lenb; i++)
string[i] = *buf++;
GD.VertexFormat(0);
GD.ColorRGB(*color);
if (*font == 0 || *font < 16 || *font > 31)
*font = 18;
GD.cmd_text(*x, *y, *font, 0, string);
Next I'll need to add in a new command to set the text colour. I'll also reuse the 'MODE" command to switch between resolutions I think.
