Using the new random function and simple points plotting, it's easy to create an animated starfield in Basic.
10 PRINT "SHOWING STARS. PRESS ANY KEY TO STOP"
15 DIM X(20): DIM Y(20)
20 FOR I=0 TO 19
25 X(I)=RND(I)*512
26 Y(I)=RND(I)*512
30 NEXT I
35 REM DRAW STARS
40 CLS $0: CLR
42 POINT 0,0,$0,4,1
45 FOR I=0 TO 19
50 POINT X(I),Y(I),$FFFFFF,1,0
51 Y(I)=Y(I)+RND(I)*50
52 IF Y(I) > 512 THEN Y(I) = 0
60 NEXT I
70 REM SWAP BUFFER
75 GDSWAP
80 GET A$
85 IF A$="" THEN GOTO 40
90 PRINT "DONE"
100 END
