You can now deploy your assistant! On the bottom right of the page will be a Deploy Assistant
button.
Use the Sam CLI Tool to deploy the assistant to your Raspberry Pi. Below is an example of the command to use.
A project log for GUILLENGAP Cobot
Collaborative Robot Arm with Artificial Intelligence, and Used as Assistant in: 1) Voice Command System & 2) Sorting Objects System
button.
