1Connect all components to Arduino
2Upload code
int WATER_PUMP = 9; int IR_SENSOR = 11; void setup() { pinMode(WATER_PUMP, OUTPUT); pinMode(IR_SENSOR, INPUT); } void loop() { int cupPresent = digitalRead(IR_SENSOR); if (cupPresent == 0) { digitalWrite(LED_BUILTIN, HIGH); digitalWrite(WATER_PUMP, HIGH); // turn Water pump ON delay(35000); // Fill 125ml of water in a glass digitalWrite(LED_BUILTIN, LOW); digitalWrite(WATER_PUMP, LOW); // turn the LED off by making the voltage LOW delay(60UL * 60UL * 1000UL); // Wait 1 hour } else { delay (1000); // Cup not present, waiting } } -
3Place cup of water
And get refreshed :)
Javier Rengel
