Hackaday.io Hackaday.io
Sign up Log in
Highlight Digitizer
Transfer highlights made with a marker on physical documents to their digital counterparts.
inneInne
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
  • 2021 Hackaday Prize
View Gallery
213
3
1
2
Team (1)
  • inneInne
Join this project's team
researching project
Software
python opencv markers OCR IMAGE RECOGNITION text matching documents 2021hackadayprize Challenge 2: Refresh Work-From-Home Life
This project is submitted for
  • Challenge 2: Refresh Work-From-Home Life
This project was created on 06/30/2021 and last updated 5 years ago.
Description
Highlighting paper documents is awesome. It improves reading comprehension
and lets you recall things easier. It is unfortunate that readers of physical
documents get a penalty for using them.
I want to make a system that transfers physical highlights back into the original
digital version. By scanning (taking a picture) of the document, isolating the
highlighted areas and using OCR we can determine what text was highlighted
and highlights the same bit in the digital copy.
Details
Log In/Sign up to comment
Sign up with Github
OR
Paul McClay wrote 07/02/2021 at 07:18 • point
I'll bet libraries around the world would love to see an "augmented reality" application to record/display all the highlighting a person would want to do without actually marking any pages.
And you wouldn't be tied to a particular single copy of whatever you're reading & hightlighting, or highlit  when you read it somewhere else n years ago.
Inne wrote 07/05/2021 at 08:55 • point
Paul, what an excellent suggestion. Also at the perfect time since, because I wanted to enter the Hackaday prize, I was still looking for a hardware aspect to this software project.
Next to the obvious digitizing use case I mainly came up with comparing how students learn differently from each other by analyzing what and where they highlight.
All in all completing this project will be a major challenge (even without the AR which I have no experience with) but it is very nice to have a point on the horizon. Thanks for your contribution.
Paul McClay wrote 07/08/2021 at 02:40 • point
You're welcome! and welcome to use & extend the idea as you wish, in case that wasn't obvious.
A Windows app which gives your numeric keypad computer-automating superpowers! Automate keystrokes using the drag-and-drop editor.
Project Owner Contributor
Numpad Superpowers
inventive-robinInventive Robin
This is a discreet four bit adder I designed and constructed using 60 RTL NAND gates.
Discreet Four Bit Adder
curtis-bucherCurtis Bucher
SAO using art from a photograph taken in Munich
Mr Fixit SAO
tomkeddieTomKeddie
GUI interface (ImGUI) for send text over radio using SDR or Transciever with Minimodem
Minimodem-ImGUI
yd1ruhYD1RUH
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Highlight Digitizer", please tell us the reason.
Send message
Remove Member
