One step closer to final product
07/18/2021 at 15:24 • 0 commentsSo I have assembled all the componrnts in 3D printed case. It`s tiny and looks awesome.
The dimension of my wearable Posture correcting Devics is marely 52x33x5mm. Now is is easy to stick on the back with some means(working on it...) to be fully functional, and provide feedback to user. Have a look:-
More photographs in gallery.
3D printed encloser
07/17/2021 at 09:47 • 0 commentsI have printed some encloser designs for my project. What I tried to fit all the components in small space to make it liye weight wearable device.
Attached picture below. Added a scale to get an idea about it's size.
Working prototype
07/14/2021 at 09:59 • 0 commentsToday build the working prototype of Posture Correcting device on breadboard. Here I have used LED instead of vibrating motor, just to visualize it. Added video/Photographs here, just have a look.
Video:
Photographs: ON/Alarming State
OFF/No Alarm State
Found a new type of microcontroller(same attiny85) for testing purpose
07/06/2021 at 04:11 • 0 commentsHello I found a Digispark device which is attiny85 microcontroller but with usb, so I am planning to use it. Since it is easy to program & test with it. Just have a look...
Its so small
Assembly in progress
07/06/2021 at 04:06 • 0 commentsAs I have gathered all the required components, so now I am on assembling the components for testing purpose.
Programming done
07/06/2021 at 03:42 • 0 commentsSo I have done with the programming part for now.
I am using Arduino IDE to program attiny85 microcontroller. This is great tool to stsrt with arduino, esp, attiny and lot many boards. Great number of library available and the great thing is community support.
Krishna Mohan
