A Maximally 3D-Printed SCARA Arm for the Budget Maker
And Software To Make It Tick!
jSCARA-V16.FCStdFreeCAD Design Filesfcstd - 5.41 MB - 07/10/2021 at 20:09 |
Here I demonstrate the writing capabilities of the jSCARA arm + software, and the precision with which the arm can write. Note that when the drawing gcode is run for a second time, the arm traces over the exact same path!
You can see the custom designed software here: https://github.com/jpoles1/jscara-console.
This software is essentially a chrome-based gcode sender which works with regular marlin (configured for a cartesian bot wherein X-Y coords sent to the SCARA are actually angles for the arms) and generates SCARA commands.
Hope that's helpful! It's definitely not a finished product, but it's what I've got so far. Overall have had a lot of issues using marlin for this project, defintiely not a perfect fit for SCARA arms.
Marlin actually does have mostly-complete SCARA support, just no documentation on how to use it. I wrote some about it here https://reprap.org/forum/read.php?185,879148
The legendary dekutree64, thanks so much for commenting! I actually came across this thread and read through it several times trying while trying to get things to work, however I did not have much success. It would be great to get your expertise in troubleshooting if you're open to lending a hand! Will send you a DM.
Do you share your software ? I don't see it here.
