YAPT
Yet Another Pomodoro Timer aka the Squishy timer
Public Chat
0 followers
A simple timer with a ring to count down. The build is done and I hope I took photos. I still need to work on code which should be reusable in your own projects
Code will be ip on GitHub when I have something working
Bill of materials
  • Seeed Xaio
  • 24 LED ring light ( Not an Adafruit Neopixel ring but only because I couldn’t get one with Amazon gift cards)
  • 2 momentary switches (part of a donor board. It is mounted under the diffuser so that the buttons can be pushed but are hidden.
External build
  • The LED diffuser is part of a opaque folder with mirrored sticker stock covering the middle.  I tried just paper, card stock, and half a clear plastic ornament ball.  None of those results looked as nice.
  • Underneath the LED ring is a clear plastic ring salvaged from a roll of large format printer paper.  This was what everything was mounted to.  It was wrapped with more mirrored stickers to cut down on light leaks.
  • The colourful outside was made with Hey Clay, a foam clay for kids.  It is easy to mold and clean up. It dries soft but shrinks a significant amount.  This is why it’s pulled back from the diffuser.
  • Not shown - lots of hot glue.  Seriously, it was a lot.
  • Github
    Steamfoundry07/19/2021 at 23:14 0 comments
    For anyone following along at home I've added the code to Github.  So far it's just a few visualizations I've coded up to test and decide what I wanted it to look like..
    https://github.com/steamfoundry/YAPT
  • Q: Why is it called squishy?
    Steamfoundry07/19/2021 at 23:12 0 comments
    A: The clay foam outside ended up almost like a stress ball and the way the buttons are mounted under the diffuser means you have to squish on the top to press them.
    Sorry, no mystery here
  • Hey Clay
    Steamfoundry07/12/2021 at 02:12 0 comments
    To anyone looking for Hey Clay that isn’t in Canada to buy it from COOP….
    Good luck.
    I just used it because it was handy and good enough for a prototype.
    if you have the cash just use Sugru for better results.
View all 3 project logs
