Github
07/19/2021 at 23:14 • 0 commentsFor anyone following along at home I've added the code to Github. So far it's just a few visualizations I've coded up to test and decide what I wanted it to look like..
Q: Why is it called squishy?
07/19/2021 at 23:12 • 0 commentsA: The clay foam outside ended up almost like a stress ball and the way the buttons are mounted under the diffuser means you have to squish on the top to press them.
Sorry, no mystery here
Hey Clay
07/12/2021 at 02:12 • 0 commentsTo anyone looking for Hey Clay that isn’t in Canada to buy it from COOP….
Good luck.
I just used it because it was handy and good enough for a prototype.
if you have the cash just use Sugru for better results.
