After the Schematic has been finalized it is time for designing a PCB.
This part is in my opinion pure ART:
After some Hours I was quite happy with the Design:
Outer diameter of the board needs to be 94mm to fit nicely in the Housing of the Deklamp
An the Mounting boards have a distance of 85mm
Top View: (hidden inside the lamp head) Version 1:
Bottom View: Partly visible. (PCB Version 1)
I tried to lactae the LEDs equaly along the board. You might notice some space. This is due to Antenna Deisgns
Ulrich
