Two words: Command Strips.
They work for practically everything. We used three hooks and added heat shrink tubing to them so the board wouldn't slip on the metal. For the button we put a command strip on the bottom and just stuck it to the wall. We used a few small zip ties to make the wires look a bit cleaner.
Alpenglow Industries
