With the help of Dante and with some identification of the hex code of the block and the text of a block I was able to change the text and color of a block (that was through editing the blocks/custom/aduino.js file, the generator/aduino/control.js file and the compressed arduino file contained within the js folder before opening the changed code using index.html. However, shape has still been difficult to find and it seems most of us have been having a similar issue. With no knowledge of how to write C code I was unable to change the output C code of a block. However, I was still able to input my own block into the program. The following images are what I was able to get done:
Great job, Gracie! I like the block names :)
