I've implemented the pulseIn function, which waits for a certain pin to rise then fall (or fall then rise):
The generator code already existed but was not compiled, and needed only a few modifications. The block code also already existed but also needed modifications. The code seems a bit disorganized which I will address in another log after some engagements today.
good stuff brother! Yeah, let's definitely talk and I look forward to picking your brain
