TopLid.stl
Lid connects to Encoder Disc. Label fits over lid.
netfabb -
211.21 kB -
07/16/2021 at 19:14
Download
Encoder_Discv2_correct_code.stl
This is the 3-bit gray encoder disc. Line the 3 bits off position with task 0 on the lid.
netfabb -
398.13 kB -
07/16/2021 at 19:14
Download
Label.stl
The label model sits on top of the top lid, meant to be changed for individual needs. Pause print for filament change on icons.
netfabb -
452.23 kB -
07/16/2021 at 19:14
Download
Base_Shaft.stl
First design was to keep photo sensors shielded but that didn't work, opted for just photo sensors placed at hole location.
netfabb -
248.81 kB -
07/16/2021 at 19:14
Download
Base_LED_PhotoSensor.stl
With locations for pin drops for the photo resistors and LED.
netfabb -
176.35 kB -
07/16/2021 at 19:14
Download
TaskTrack.ino
Arduino Code for 3 sensors and gray code to number conversion. outputs to serial
ino -
2.03 kB -
07/16/2021 at 19:13
Download
