Shell_Top.stl
STL File of the top half of the badge. When printing, keep two things in mind: 1) The Filament is supposed to be swapped to a clear filament after the top horizontal layer is finished, to create the see-through ring for the notification LEDs
2) Three M1.5 nuts have to be embedded within the print, so it must be paused before the top covers of the three screw mounting posts are printed. The nuts can be inserted with a bit of force (tune printer to make it snap-fit), then continue printing.
Optionally sand down the front of the casing to make it smoother.
model/stl -
388.66 kB -
10/04/2021 at 07:36
Download
