Small test
07/19/2021 at 02:15 • 0 commentsThis Saturday I ... of trying to make myself the smallest PCB that I've designed, I'm pretty happy with the result, but i don't think I'll be trying nothing like this any time soon lol
I made the vias using a 0.4mm drill bit and connected both sides with a thin wire a lot of patience
Passing the wires trough all the small holes
And soldering using solder paste and a heat gun
I think one led its good enough for this test, I learned that it is feasible to build such small PCBs, maybe next time I'll use a thinner material.
Here the first blink test using a nodemcu board and the homemade PCB
I'll order some PCBs from jlcpcb on Monday, I'm so excited! Let me know what you think :D
PCB Design
07/19/2021 at 01:57 • 0 commentsFlower is based on a ESP01 module programmed via USB, and controlled via Wifi. It have one button for control and five RGB LEDs that can display any number of animated visual signals.
I designed the control system to be housed in a thumb-stick-like enclosure, or optionally using an extension.
For the interactive part I designed a cute PCB with only 11mm in diameter:
In the other side, it have pin connections for a cable and a push button.
The idea is to have it enclosed in a flexible silicon-like material (maybe hot glue for a first prototype)
