Open Source Transparent Watch - T1
A open source transparent watch, ultra-thin, BLE, 20mm strap
I've used some smart watches, but their appearance is almost the same. They're not cool enough. I don't want to wear them after a while. I want to make a special watch for myself, which is not on the market. Seeing that transparent OLEDs are sold in the market, I came up with the idea of making a transparent watch. I want to make it thinner. The first version may not be supported by too many functions, focusing on the realization of basic functions and verifying some visual experience.
Hardware
  • 1.51 OLED   ssd1309   SPI
  • TPS61040DBVR (DCDC Vbat --> 12.5V)
  • TP4054 (charge)
  • PCB (0.8mm)
LCEDA.zip
SCH&PCB_V1.1
x-zip-compressed - 829.58 kB - 08/17/2021 at 02:51
Download
CH573DS1.PDF
kswps - 1.13 MB - 08/07/2021 at 08:31
Preview
CH573SCH_R0_1v2.pdf
kswps - 85.87 kB - 08/07/2021 at 08:31
Preview
ZJY-2856KLBAG01.pdf
1.51 oled module
kswps - 16.30 MB - 07/21/2021 at 10:16
Preview
SSD1309.pdf
IC
kswps - 1.72 MB - 07/21/2021 at 10:16
Preview
  • update
    Modular09/30/2021 at 12:08 0 comments
    Video
    Next, I'll add more low-power processing, as well as more types of clocks that show different clocks whenever I wake up my watch
  • Acc
    Modular08/28/2021 at 08:28 0 comments
    I've been able to get data on BMA423, but some features don't work.
    I temporarily purchased some QMA7981 as an alternative.
    But while I wait, I'll continue to see what the problem is.
  • Power on
    Modular08/22/2021 at 08:53 0 comments
    After receiving PCB v1.1 and welding, everything is working fine.
    Next I'll start writing code.
  • Assemble
    Modular08/17/2021 at 03:15 0 comments
    I printed the 3D case and the assembly worked well.
  • Ver_1.1
    Modular08/17/2021 at 02:50 0 comments
    Version 1.0 has some minor issues.
    In version 1.1 I modified the position of the connector.
    Use lceda to open the source file.
  • PCB
    Modular08/15/2021 at 08:40 0 comments
    I finally received the PCB today.
  • ch573 Rev 1.0
    Modular08/10/2021 at 11:31 0 comments
    The schematic and pcb have been drawn and are ready to be sent to the manufacturer
  • new schematic
    Modular08/08/2021 at 10:23 0 comments
    There are two acceleration sensors, one of which you can select as needed.
    Because ch573 does not support hardware IIC, the SPI interface is used to communicate with the accelerometer.
    If you have any better suggestions, please let me know.
  • CH573 log
    Modular08/08/2021 at 02:52 0 comments
  • CH573 + OLED
    Modular08/07/2021 at 08:28 0 comments
    A few days ago, I received the CH573 development board from WCH, so I'd like to try this chip.
    and here is some overview of the chip:
    • 32-bit RISC processor WCH RISC-V3A
    • Supports the RV32 IMAC instruction set, single-cycle multiplication and hardware division
    • Built-in 18K SRAM, 512K Flash ROM, ICP, ISP and IAP support for OTA wireless upgrades
    • Integrated 2.4GHz RF transceivers and baseband and link control to improve optimized protocol stack and application layer APIs to support networking
    • Supports 3.3V and 2.5V power supplies, built-in DC/DC conversion, and 0dBm transmits power with a current of 6mA
    • Various low power modes: Idle, Halt, Sleep, Shutdown, built-in battery voltage low voltage monitoring, minimum sleep current 0.3uA
    • Built-in USB controller and USB transceiver for USB 2.0 full-speed and low-speed hosts or devices
    • Built-in real-time clock RTC supports timing and triggering modes
    • An 8-channel 12-bit ADC-to-digital converter is available to support 8-channel touch keys
    • Provides 4 sets of 26-bit timers, supports capture/sampling, supports 4 26-bit PWM outputs, and supports 6 8-bit PWM outputs
    • Available in 4 sets of stand-alone UART, compatible with 16C550, with a maximum communication port rate of up to 6Mbps
    • Available in 1 set of SPIs, built-in FIFO, support for Master and Slave modes
    • Built-in temperature sensor
    • Available in 20 GPIO, 4 of which support 5V signal input, all GPIO support interrupt and wake-up functions
    • Built-in AES-128 plus decryption unit, chip unique ID
    • Package: QFN28_4X4
    I've ported the u8g2 library to this chip.
View all 14 project logs
