Source is PUBLIC
08/05/2021 at 12:49 • 0 commentsHello there,
just pushed the, still raw, source code to a public repository on GitHub.
https://github.com/chmod775/SMARTResponseTerminal
Be free to have a ride also on other public repos I've done.
Stay tuned,
schematic and cleaner code coming!
How the project evolved?
07/27/2021 at 12:02 • 0 commentsStarted with the idea to fit a small single board computer with WiFi into the SMART Response XE.
A Raspberry Zero W would have fitted it perfectly, but unfortunately I had any available in the lab (and delivery times were too long).
After some trial and error I managed to find and fit a NanoPi Neo Air in the battery compartment.
Unfortunately that raised another problem, how to power the device?
The immediate idea was to fit a USB power bank inside to retain the important feature of recharging and powering down the device.
That didn’t work as smoothing as I thought. Battery size like 14335 and over where too big for the case.
So I disassembled a small 2S battery for a micro drone and used both cells.
About the software, it was pretty straightforward. Replicate a VT100 terminal running on the onboard ATMega and comunicate with the single board computer using serial.
I’m planning to release the source code and some schematics soon.
Keep update on my GitHub account https://github.com/chmod775
Booting video
07/23/2021 at 14:44 • 0 commentsSimple video about the device booting.
