New version of Raspberry Pi TV Stick
05/08/2026 at 10:08 • 0 commentsThere is a newer version of the board, designed specifically for Raspberry Pi CM5:
https://hackaday.io/project/205651-raspberry-pi-cm5-tv-stick-lite
It’s available for purchase at Makerfabs:
https://www.makerfabs.com/raspberry-pi-cm5-tv-stick-lite.html
Everything is better with LEDs
08/17/2021 at 14:22 • 0 commentsWS2812 LED strip arrived and after some soldering works nicely
Next will be testing WS2801
Pre-production boards
08/14/2021 at 00:40 • 0 commentsPre-production boards have arrived!
Time to test ambilight connector.
Testing
07/31/2021 at 21:34 • 0 commentsTested built in IR receiver and to a big surprise it can receive signal despite of being behind TV and looking towards the wall.
pi@raspberrypi:~ $ irw 00000000e0e0e01f 00 KEY_VOLUMEUP remote 00000000e0e0e01f 01 KEY_VOLUMEUP remote 00000000e0e0d02f 00 KEY_VOLUMEDOWN remote 00000000e0e0d02f 01 KEY_VOLUMEDOWN remote 00000000e0e0e01f 00 KEY_VOLUMEUP remote 00000000e0e0d02f 00 KEY_VOLUMEDOWN remote 00000000e0e020df 00 BTN_1 remote 00000000e0e0e01f 00 KEY_VOLUMEUP remote 00000000e0e0d02f 00 KEY_VOLUMEDOWN remote 00000000e0e020df 00 BTN_1 remote 00000000e0e0d02f 00 KEY_VOLUMEDOWN remote 00000000e0e0e01f 00 KEY_VOLUMEUP remote
Also tested with eMMC version of CM4 for flashing.
To enter eMMC programming mode:- USB multiplexer selector switch to USB-C position
- Press and hold User Button
- Connect USB-C cable
- Release User Button
- Follow software procedure
Still have to think how and where to fit connector or solder pads for Ambilight...
