The Indifferent Engine "Janky" Tape Echo
An open source project to design and build a janky retro tape echo effect from readily available parts.
Tape echo effects sound cool, but are expensive and/or hard to find and maintain. Whilst there have been many DIY examples over the years these usually rely on finding a 3 head tape machine as a prerequisite requirement of the build. As a result, 3 head machines are becoming scarce. So, I decided to try and build a unit from a 1 head cassette player and then add in the extra heads by 3D printing a new section for the transport that allows the erase and record heads to be mounted. It would also use custom electronics as much as possible.
I want this build to be "easily" repeatable by other people, so all parts need to be easy to source or easy to create at home.
Below is a video demonstration of the MkII design, which is now available to download.
The first official release, the MkII machine
Below is a video demonstration of the prototype Mk I design.
The project is located on github, here:
https://github.com/indifferentengine/JankyTapeEcho
More info:
https://www.indifferentengine.com/tapeecho
Build instructions are via our website:
https://www.indifferentengine.com/tapeechobuildguide
Indifferent Engine are a post-hardcore band from Cambridge, UK. We also make weird pedals.
Olivia Heui Young Park
Fraens
Wow... Blast from the past! I haven't seen a tape echo since the 80s. Cool project. 👍
