Hackaday.io Hackaday.io
Sign up Log in
Liftmaster Gate WiFi hack
Using an ESP8266 to add wifi functionality to my gate so i can open and close it over MQTT
daniel-johnsonDaniel Johnson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
686
0
2
2
Team (1)
  • daniel-johnsonDaniel Johnson
Join this project's team
  • Source Code
ongoing project
ESP8266 mqtt Gate wifi Node-RED automatic opener
This project was created on 08/05/2021 and last updated 5 years ago.
Description
I used an ESP8266 to add WiFi functionality to my gate so that i can open and close the gate over MQTT. This in conjunction with my freshtomato flashed routers, I am able to automatically open and close the gate when my phone connects to the router located at the gate. I am using node-red for the backend presence detection and gate logic.
Files
Device Activity Flow.json
node-red device activity flow
JavaScript Object Notation (JSON) - 52.27 kB - 08/05/2021 at 00:53
Download
Gate Flow.json
node-red gate flow
JavaScript Object Notation (JSON) - 9.45 kB - 08/05/2021 at 00:53
Download
Gate Gerber.zip
Zip Archive - 44.69 kB - 08/05/2021 at 00:40
Download
Gate.zip
Eagle schematic and board
Zip Archive - 605.30 kB - 08/05/2021 at 00:39
Download
Project Logs
Collapse
  • Video demonstration
    Daniel Johnson • 08/05/2021 at 00:52 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
The purpose of this project is to develop a family of logic circuits using discrete components.
Project Owner Contributor
Discrete Component Logic Family
harvey-sugarHarvey Sugar
Three-inverter ring oscillator with fourth gate as a buffer
Ring Oscillators: Fairchild DTL 949
dana-myersDana Myers
Use op amps to create digital logic gates and higher level logic functions.
Op Amp Logic
dduckertdduckert
Using Hardware and software to create the programming building blocks.
Rosetta stone of hardware programming
fourthlevelmfgFourthLevelMfg
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Liftmaster Gate WiFi hack", please tell us the reason.
Send message
Remove Member
