If you set your Audio volume high you canhear the wristband vibrating, the more close the object is, the faster it vibrates. It detects object up to 4 meters.
A project log for T.O.F. Wristband V2
An assistive device for visually imparied people, it measures the distance between the user's wrist to obstacles and vibrates proportionally
