There is nothing better but 3D printed parts for a 3D printer
04/13/2025 at 18:56 • 1 commentAfter the second gearbox started to become louder over time, I have now designed a 3D printed version:
So far it works great!
A major milestone: Part 5 of the Prusa conversion
03/19/2025 at 19:34 • 0 commentsIt was a long way from the early prototypes in 2021 when the Hackaday Prize triggered the project, to a working 3D printer that converts plastic powder from failed prints into something new:
...but still not finished. I am currently working on a 3D printed gearbox for the extruder motor.
Old prints to raw material with a hacked mill
02/26/2025 at 08:55 • 0 commentsWith the converted Prusa getting closer to my everyday 3D printer, I need more raw material. I modified a commercial mill to a grinder with integrated sieve. The material throughput I get is definitively good enough, however there are still some things to improve:
More printing discloses weak points of the design
02/15/2025 at 07:20 • 0 commentsThe granule printer meanwhile works very well and I start doing more than just print tests and with that the weak points can be seen. I have to replace a too weak gearbox and must redesign the powder feed.
Meanwhile, close to a _normal_ printer
09/29/2024 at 15:21 • 0 commentsI have modified the mechanics of the Prusa again. This time I had an eye on better usability of the printer. Furthermore I am working on the automatic material feed. The parts needed for this were all printed from PLA powder. The machine gets closer to a printer that is almost like a _normal_ (filament) printer:
The full print of a small part is demonstrated in another video:
First 3D Benchy printed from PLA granules
09/07/2024 at 10:49 • 3 commentsThe load cell of the Prusa MK4 is implemented and so bed leveling works fine. Now that larger prints can be carried out, I have made a Benchy:
If you know a granule FDM printer that can make better looking Benchies, leave a comment!
Extruding PLA powder required changes in the design
07/22/2024 at 14:10 • 0 commentsI got some PLA powder and trying to print with this raw material didn't work with version 5.0 of my granule extruder. I had to shorten the extruder tube (again) and make some more changes to the hardware, but now printing with the powder works:
My Prusa MK4 no longer needs filament to print
06/07/2024 at 13:57 • 1 commentI am in the process of converting a Prusa MK4 to granule printing. Part 1 of the process shows how to build the core component, extruder V5.0 and first test prints:
A closer look at the auger screw(s) of my direct granules 3D printer
05/10/2024 at 11:40 • 0 commentsThe simplest component of my granule extruder must meet certain criteria to get a working 3D printer:
Next step: Converting a Prusa MK4 to direct granule printing.
Extruder V4.1: Rough build instructions and thermal optimization
04/27/2024 at 12:54 • 0 commentsI have been shrinking the tube of my extruder in order to reduce friction and so to get a better retract:
Norbert Heinz
