Step 5 (option B): Configure buildroot
08/13/2021 at 09:34 • 0 commentsIn the last step we're use Armbian distribution to take snapshot of the root filesystem, as well as boot artifacts.
Alternatively to that we can generate root filesystem as well as boot artifacts using [buildroot](https://github.com/buildroot/buildroot)
In short this is a set of tools and scripts that allows you to generate and build small yet extremely powerfull (and very much configurable) linux distribution. It will build u-boot (we don't need that), kernel and root filesystem specifically for our Orange Pi.
Execute following step on the dev machine
$ cd ~/pi-boot/ $ git clone https://github.com/anabolyc/buildroot-orange-pi-zero && cd buildroot-orange-pi-zero $ git submodule update --init $ cd buildroot $ make orangepi_zero_defconfig # optional, but you might want to configure root password, host name or something else to your taste $ make menuconfig $ make
This will take a while, and in the end it will output
[...] INFO: vfat(boot.vfat): cmd: "dd if=/dev/zero of="/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/boot.vfat" seek=10485760 count=0 bs=1 2>/dev/null" (stderr): INFO: vfat(boot.vfat): cmd: "mkdosfs '/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/boot.vfat'" (stderr): INFO: vfat(boot.vfat): adding file 'zImage' as 'zImage' ... INFO: vfat(boot.vfat): cmd: "MTOOLS_SKIP_CHECK=1 mcopy -bsp -i '/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/boot.vfat' '/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/zImage' '::'" (stderr): INFO: vfat(boot.vfat): adding file 'sun8i-h2-plus-orangepi-zero.dtb' as 'sun8i-h2-plus-orangepi-zero.dtb' ... INFO: vfat(boot.vfat): cmd: "MTOOLS_SKIP_CHECK=1 mcopy -bsp -i '/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/boot.vfat' '/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/sun8i-h2-plus-orangepi-zero.dtb' '::'" (stderr): INFO: vfat(boot.vfat): adding file 'boot.scr' as 'boot.scr' ... INFO: vfat(boot.vfat): cmd: "MTOOLS_SKIP_CHECK=1 mcopy -bsp -i '/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/boot.vfat' '/media/dronische/storage/buildroot-orange-pi-zero/buildroot/output/images/boot.scr' '::'" (stderr): INFO: hdimage(sdcard.img): adding partition 'u-boot' from 'u-boot-sunxi-with-spl.bin' ... INFO: hdimage(sdcard.img): adding partition 'boot' (in MBR) from 'boot.vfat' ... INFO: hdimage(sdcard.img): adding partition 'rootfs' (in MBR) from 'rootfs.ext4' ... INFO: hdimage(sdcard.img): writing MBR
Now we have everything we need locally, just need to copy that to both NFS and TFTP servers
$ mkdir -p ~/pi-boot/mnt/{sdc,nfs} && cd ~/pi-boot $ sudo mount 192.168.1.3:/srv/exports mnt/nfs $ sudo mkdir mnt/nfs/01-02-42-94-b4-99-28-buildroot $ ls -la mnt/nfs total 16 drwxr-xr-x 4 root root 4096 sie 13 10:25 . drwxrwxr-x 4 dronische dronische 4096 sie 13 08:52 .. drwxr-xr-x 18 root root 4096 sie 13 09:54 01-02-42-94-b4-99-28 drwxr-xr-x 16 root root 4096 sie 12 21:10 01-02-42-94-b4-99-28-buildroot $ sudo rsync -va ~/pi-boot/buildroot-orange-pi-zero/buildroot/output/staging/ mnt/nfs/01-02-42-94-b4-99-28-buildroot
Next lets copy kernel and device tree to TFTP share
$ scp ~/pi-boot/buildroot-orange-pi-zero/buildroot/output/images/{zImage,sun8i-h2-plus-orangepi-zero.dtb} 192.168.1.2:/srv/tftp
And edit boot config (from TFTP server now)
$ cd /srv/tftp $ sudo mkdir dtb-buildroot && mv sun8i-h2-plus-orangepi-zero.dtb ./dtb-buildroot $ sudo nano pxelinux.cfg/01-02-42-94-b4-99-28
Content of the file
LABEL linux KERNEL vmlinuz-5.10.43-sunxi FDTDIR dtb-5.10.43-sunxi APPEND root=/dev/nfs initrd=uInitrd-5.10.43-sunxi nfsroot=192.168.1.3:/srv/exports/01-02-42-94-b4-99-28 ip=dhcp rw LABEL buildroot KERNEL zImage FDTDIR dtb-buildroot APPEND root=/dev/nfs nfsroot=192.168.1.3:/srv/exports/01-02-42-94-b4-99-28-buildroot,vers=4 ip=dhcp rw DEFAULT buildroot
Now let's reboot our PI
U-Boot SPL 2020.10-armbian (Aug 08 2021 - 16:21:05 +0200) DRAM: 256 MiB Trying to boot from sunxi SPI U-Boot 2020.10-armbian (Aug 08 2021 - 16:21:05 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... MMC: no card present In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds MMC: no card present Device 0: unknown device ethernet@1c30000 Waiting for PHY auto negotiation to complete. done BOOTP broadcast 1 DHCP client bound to address 192.168.1.49 (9 ms) Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/pxelinux.0'. Load address: 0x42000000 Loading: * TFTP error: 'File not found' (1) Not retrying... missing environment variable: pxeuuid Retrieving file: /pxelinux.cfg/01-02-42-94-b4-99-28 Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/pxelinux.cfg/01-02-42-94-b4-99-28'. Load address: 0x43200000 Loading: # 113.3 KiB/s done Bytes transferred = 348 (15c hex) Config file found 2: buildroot Retrieving file: /zImage Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/zImage'. Load address: 0x42000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ##################################### 1.5 MiB/s done Bytes transferred = 5304176 (50ef70 hex) append: root=/dev/nfs nfsroot=192.168.1.3:/srv/exports/01-02-42-94-b4-99-28-buildroot ip=dhcp rw Retrieving file: /dtb-buildroot/sun8i-h2-plus-orangepi-zero.dtb Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/dtb-buildroot/sun8i-h2-plus-orangepi-zero.dtb'. Load address: 0x43000000 Loading: ## 1.3 MiB/s done Bytes transferred = 23221 (5ab5 hex) ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Device Tree to 49ff7000, end 49fffab4 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.12.2 (dronische@dronische-desktop) (arm-buildroot-linux-uclibcgnueabihf-gcc.br_real (Buildroot 2021.08-rc1-92-ge2d2cd94e0) 10.3.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP Thu Aug 12 21:29:13 CEST 2021 [...] [ 9.945333] random: crng init done Starting sshd: OK Welcome to Buildroot for the Orange Pi Zero opi-z45 login:
And there is your login screen.
Step 5: Configure NFS server and finish TFTP config
08/13/2021 at 08:14 • 0 commentsNow we need to prepare Pi specific files. There are number of ways doing this. Simplest one is to take files from SD card that we have prepared earlier. But first let's prepare last server in the setup - NFS server. This will provide root filesystem fro our Pi over network and preferably should have fast storage and wide connection to PI. But of course that is only optional.
In my case it is ubuntu machine under 192.168.1.3 IP, but it can be combined with TFTP and/or DHCP server as well.
$ sudo apt install nfs-kernel-server -y $ sudo mkdir -p /srv/exports/01-02-42-94-b4-99-28 $ sudo nano /etc/exports
Contents of exports config:
/srv/exports 192.168.1.0/24(rw,no_root_squash,async,insecure,no_subtree_check,crossmnt)
You can play around with settings, above those working best for me. Key issue you might address is that all machines in the network are allowed to connect to that NFS export without authorisation. This is okay for me, but you might want to have different setup, perhaps not as much trusted.
Now lets update service
$ sudo exportfs -rv
Now we're back at dev machine, where we can take snapshot from SD card
$ mkdir -p ~/pi-boot/mnt/{sdc,nfs} && cd ~/pi-boot $ sudo mount /dev/sdc1 mnt/sdc $ sudo mount 192.168.1.3:/srv/exports mnt/nfs $ ls -la mnt/nfs/ total 12 drwxr-xr-x 3 root root 4096 sie 13 08:49 . drwxrwxr-x 4 dronische dronische 4096 sie 13 08:52 .. drwxr-xr-x 2 root root 4096 sie 13 08:49 01-02-42-94-b4-99-28 $ sudo rsync -va mnt/sdc/ mnt/nfs/01-02-42-94-b4-99-28 sent 987,891,328 bytes received 708,418 bytes 6,009,724.90 bytes/sec total size is 985,196,807 speedup is 1.00
Few small fixes that we need to apply on the root filesystem
# we no longer need this, it is stored on TFTP now $ sudo rm -rf mnt/nfs/01-02-42-94-b4-99-28/boot # edit fstab $ sudo nano mnt/nfs/01-02-42-94-b4-99-28/etc/fstab
Need to comment first line, since we no longer have SD-card
# UUID=3dbf7aef-312c-456c-a992-e6bde7857d3f / ext4 defaults,noatime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0
Next we need to prepare boot artifacts on TFTP server
$ cd ~/pi-boot/mnt/sdc/boot $ scp -r uInitrd-5.10.43-sunxi vmlinuz-5.10.43-sunxi dtb-5.10.43-sunxi 192.168.1.2:/srv/tftp
Note that names above are those specified in boot config file created at previous step.
Last thing is to restore permissions on the TFTP share$ sudo chown root:root /srv/tftp -R
New let's try to boot Pi
Autoboot in 1 seconds MMC: no card present Device 0: unknown device ethernet@1c30000 Waiting for PHY auto negotiation to complete. done BOOTP broadcast 1 DHCP client bound to address 192.168.1.49 (9 ms) Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/pxelinux.0'. Load address: 0x42000000 Loading: * TFTP error: 'File not found' (1) Not retrying... missing environment variable: pxeuuid Retrieving file: /pxelinux.cfg/01-02-42-94-b4-99-28 Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/pxelinux.cfg/01-02-42-94-b4-99-28'. Load address: 0x43200000 Loading: # 63.5 KiB/s done Bytes transferred = 195 (c3 hex) Config file found 1: linux Retrieving file: /uInitrd-5.10.43-sunxi Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/uInitrd-5.10.43-sunxi'. Load address: 0x43300000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ###### 961.9 KiB/s done Bytes transferred = 11527719 (afe627 hex) Retrieving file: /vmlinuz-5.10.43-sunxi Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/vmlinuz-5.10.43-sunxi'. Load address: 0x42000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ######################## 1.6 MiB/s done Bytes transferred = 7975912 (79b3e8 hex) append: root=/dev/nfs initrd=uInitrd-5.10.43-sunxi nfsroot=192.168.1.3:/srv/exports/01-02-42-94-b4-99-28 ip=dhcp rw Retrieving file: /dtb-5.10.43-sunxi/sun8i-h2-plus-orangepi-zero.dtb Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/dtb-5.10.43-sunxi/sun8i-h2-plus-orangepi-zero.dtb'. Load address: 0x43000000 Loading: ### 1.4 MiB/s done Bytes transferred = 7975912 (79b3e8 hex) append: root=/dev/nfs initrd=uInitrd-5.10.43-sunxi nfsroot=192.168.1.3:/srv/exports/01-02-42-94-b4-99-28 ip=dhcp rw Retrieving file: /dtb-5.10.43-sunxi/sun8i-h2-plus-orangepi-zero.dtb Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/dtb-5.10.43-sunxi/sun8i-h2-plus-orangepi-zero.dtb'. Load address: 0x43000000 Loading: ### done Bytes transferred = 32623 (7f6f hex) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11527655 Bytes = 11 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 49501000, end 49fff5e7 ... OK Loading Device Tree to 494f6000, end 49500f6e ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [...] Welcome to Armbian 21.05.8 Focal! [ 12.117995] systemd[1]: Set hostname to <orangepizero>. [ 14.946538] random: systemd: uninitialized urandom read (16 bytes read) [ 14.963400] systemd[1]: Created slice system-modprobe.slice. [ OK ] Created slice system-modprobe.slice. [ 14.985435] random: systemd: uninitialized urandom read (16 bytes read) [ 14.995698] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 15.017352] random: systemd: uninitialized urandom read (16 bytes read) [ 15.026947] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 15.049462] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 15.063627] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 15.091474] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ OK ] Set up automount Arbitrary…s File System Automount Point. [ 15.117752] systemd[1]: Reached target Local Encrypted Volumes. [ OK ] Reached target Local Encrypted Volumes. [ 15.142265] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 15.161495] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 15.181396] systemd[1]: Reached target System Time Set. [ OK ] Reached target System Time Set. [ 15.250879] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 15.277568] systemd[1]: Listening on Syslog Socket. [ OK ] Listening on Syslog Socket. [ 15.298325] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 15.325530] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 15.350716] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 15.374799] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 15.396215] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 15.418365] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 15.442714] systemd[1]: Condition check resulted in Huge Pages File System being skipped. [ 15.462566] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 15.497497] systemd[1]: Mounting RPC Pipe File System... Mounting RPC Pipe File System... [ 15.532004] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 15.566765] systemd[1]: Mounting Kernel Trace File System... Mounting Kernel Trace File System... [ 15.609371] systemd[1]: Starting Restore / save the current clock... Starting Restore / save the current clock... [ 15.648788] systemd[1]: Starting Set the console keyboard layout... Starting Set the console keyboard layout... [ 15.689001] systemd[1]: Starting Create list of static device nodes for the current kernel... Starting Create list of st…odes for the current kernel... [ 15.717760] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped. [ 15.740482] systemd[1]: Started Nameserver information manager. [ OK ] Started Nameserver information manager. [ 15.764910] systemd[1]: Reached target Network (Pre). [ OK ] Reached target Network (Pre). [ 15.802048] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 15.841493] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 15.876037] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 15.916208] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ 15.955215] systemd[1]: Mounted POSIX Message Queue File System. [ OK ] Mounted POSIX Message Queue File System. [ 15.979677] systemd[1]: Mounted RPC Pipe File System. [ OK ] Mounted RPC Pipe File System. [ 16.003642] systemd[1]: Mounted Kernel Debug File System. [ OK ] Mounted Kernel Debug File System. [ 16.027692] systemd[1]: Mounted Kernel Trace File System. [ OK ] Mounted Kernel Trace File System. [ 16.057958] systemd[1]: Finished Restore / save the current clock. [ OK ] Finished Restore / save the current clock. [ 16.092434] systemd[1]: Finished Create list of static device nodes for the current kernel. [ OK ] Finished Create list of st… nodes for the current kernel. [ 16.136849] systemd[1]: Finished Remount Root and Kernel File Systems. [ OK ] Finished Remount Root and Kernel File Systems. [ 16.191826] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 16.201833] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 16.226127] systemd[1]: Starting Load/Save Random Seed... Starting Load/Save Random Seed... [ 16.275198] systemd[1]: Starting Create System Users... Starting Create System Users... [ 16.421991] g_serial gadget: Gadget Serial v2.4 [ 16.426683] g_serial gadget: g_serial ready [ 16.445720] systemd[1]: Finished Load Kernel Modules. [ OK ] Finished Load Kernel Modules. [ 16.480504] systemd[1]: Mounting FUSE Control File System... Mounting FUSE Control File System... [ 16.517396] systemd[1]: Mounting Kernel Configuration File System... Mounting Kernel Configuration File System... [ 16.557111] systemd[1]: Starting Apply Kernel Variables... Starting Apply Kernel Variables... [ 16.591086] systemd[1]: Finished Create System Users. [ OK ] Finished Create System Users. [ 16.616939] systemd[1]: Mounted FUSE Control File System. [ OK ] Mounted FUSE Control File System. [ 16.639662] systemd[1]: Mounted Kernel Configuration File System. [ OK ] Mounted Kernel Configuration File System. [ 16.675480] systemd[1]: Starting Create Static Device Nodes in /dev... Starting Create Static Device Nodes in /dev... [ OK ] Finished Set the console keyboard layout. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished udev Coldplug all Devices. Starting Helper to synchronize boot up for ifupdown... [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... Starting udev Kernel Device Manager... [ OK ] Finished Helper to synchronize boot up for ifupdown. [ OK ] Mounted /tmp. [ OK ] Reached target Local File Systems. Starting Armbian ZRAM config... Starting Set console font and keymap... Starting Raise network interfaces... Starting Preprocess NFS configuration... [ OK ] Finished Set console font and keymap. [ OK ] Finished Preprocess NFS configuration. [ OK ] Reached target NFS client services. [ OK ] Finished Load/Save Random Seed. [ OK ] Started udev Kernel Device Manager. [ OK ] Found device /dev/ttyGS0. [ 18.873471] thermal thermal_zone0: binding zone cpu_thermal with cdev thermal-cpufreq-0 failed:-22 [ OK ] Found device /dev/ttyS0. [ OK ] Finished Raise network interfaces. [ OK ] Finished Armbian ZRAM config. Starting Armbian memory supported logging... [ OK ] Finished Armbian memory supported logging. Starting Journal Service... [ OK ] Started Journal Service. Starting Flush Journal to Persistent Storage... [ OK ] Finished Flush Journal to Persistent Storage. Starting Create Volatile Files and Directories... [ OK ] Finished Create Volatile Files and Directories. [ OK ] Started Entropy daemon using the HAVEGE algorithm. Starting RPC bind portmap service... Starting Network Name Resolution... Starting Update UTMP about System Boot/Shutdown... [ OK ] Finished Update UTMP about System Boot/Shutdown. [ OK ] Reached target System Initialization. [ OK ] Started resolvconf-pull-resolved.path. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Paths. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. Starting Armbian hardware monitoring... Starting Armbian hardware optimization... [ OK ] Started RPC bind portmap service. [ OK ] Reached target Remote File Systems (Pre). [ OK ] Reached target Remote File Systems. [ OK ] Reached target RPC Port Mapper. [ OK ] Finished Armbian hardware monitoring. [ OK ] Finished Armbian hardware optimization. [ OK ] Reached target Basic System. [ OK ] Started Regular background program processing daemon. [ OK ] Started D-Bus System Message Bus. Starting Network Manager... [ OK ] Started Save initial kernel messages after boot. Starting Remove Stale Onli…t4 Metadata Check Snapshots... Starting LSB: Load kernel …d to enable cpufreq scaling... Starting Dispatcher daemon for systemd-networkd... [ OK ] Started Add entropy to /de…random 's pool a hardware RNG. Starting System Logging Service... Starting Self Monitoring a…g Technology (SMART) Daemon... Starting Resets System Activity Data Collector... Starting Login Service... Starting WPA supplicant... [ OK ] Finished Resets System Activity Data Collector. [ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots. [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. Starting resolvconf-pull-resolved.service... [ OK ] Started System Logging Service. [ OK ] Started Self Monitoring an…ing Technology (SMART) Daemon. [ OK ] Started Login Service. [ OK ] Started WPA supplicant. [ OK ] Started LSB: Load kernel m…ded to enable cpufreq scaling. Starting LSB: set CPUFreq kernel parameters... [ OK ] Finished resolvconf-pull-resolved.service. [ OK ] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs va i orangepizero login: Armbian 21.05.8 Focal ttyS0 ___ ____ _ _____ / _ \| _ \(_) |__ /___ _ __ ___ | | | | |_) | | / // _ \ '__/ _ \ | |_| | __/| | / /| __/ | | (_) | \___/|_| |_| /____\___|_| \___/ Welcome to Armbian 21.05.8 Focal with Linux 5.10.43-sunxi System load: 2% Up time: 4 min Memory usage: 29% of 238M IP: 192.168.1.49 CPU temp: 51°C Usage of /: 60% of 8.8G [ General system configuration (beta): armbian-config ] Last login: Wed Aug 11 22:19:50 UTC 2021 from 192.168.1.110 on pts/0
Logon successful! -
Step 4: Configure TFTP server
08/13/2021 at 06:35 • 0 commentsWhen Pi boots it will request certain files from TFTP server. It is very simple server with no authentication and it only server few files, among which kernel, initrd and boot config.
First we will configure some TFTP server, then we will upload those resources.
So next commands are executed on 192.168.1.2 machine, which is ubuntu in my case
$ sudo apt install tftpd-hpa -y $ sudo nano /etc/default/tftpd-hpa $ sudo chown $UID:$UID /srv/tftp -R $ mkdir /srv/tftp/pxelinux.cfg $ nano /srv/tftp/pxelinux.cfg $ nano /srv/tftp/pxelinux.cfg/01-02-42-94-b4-99-28
Content of that file is
LABEL linux KERNEL vmlinuz-5.10.43-sunxi FDTDIR dtb-5.10.43-sunxi APPEND root=/dev/nfs initrd=uInitrd-5.10.43-sunxi nfsroot=192.168.1.3:/srv/exports/01-02-42-94-b4-99-28 ip=dhcp rw DEFAULT linux
As you can see above, configuration is per MAC address, so I can have multiple device configurations in the network.
For now we don't have yet kernel, initrd and dtb files, we will fix that in a minute. Also we inform that NFS server will be under 192.168.1.3 address which not exists yet.
In the Pi boot log we're one step closer
[...] Autoboot in 1 seconds MMC: no card present Device 0: unknown device ethernet@1c30000 Waiting for PHY auto negotiation to complete. done BOOTP broadcast 1 DHCP client bound to address 192.168.1.49 (8 ms) Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/pxelinux.0'. Load address: 0x42000000 Loading: * TFTP error: 'File not found' (1) Not retrying... missing environment variable: pxeuuid Retrieving file: /pxelinux.cfg/01-02-42-94-b4-99-28 Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/pxelinux.cfg/01-02-42-94-b4-99-28'. Load address: 0x43200000 Loading: # 43.9 KiB/s done Bytes transferred = 183 (b7 hex) Config file found 1: linux Retrieving file: /initrd.img-5.10.43-sunxi [...]
Next we'll prepare files specific for Pi both on TFTP server and NFS server
Step 3: Configure DHCP server
08/12/2021 at 21:17 • 0 commentsNow when our Pi asking to boot from network we need someone to answer it. First to respond will be DHCP server, whose role is to assign IP address (I prefer static one, but it is not strictly necessary) and instruct to get boot resources from TFTP server.
I assume you already have some kind of DHCP server within your network, normally that would be a network router, but might be dedicated machine. Im my case it is running [OpenWrt](https://openwrt.org/) and I'm able to ssh in it.
Following changes are executed at router filesystem.
# nano /etc/config/dhcp
Add below config to the bottom
config boot 'linux' option filename '/pxelinux.0' option serveraddress '192.168.1.2' option servername 'netbootsrv' config host option name 'opi-zero-z4' option mac '02:42:94:b4:99:28' option ip '192.168.1.48'
For boot section we define basic structure that expected to exist on TFTP server and actual IP of netboot server, which is 192.168.1.2 in my case.
For Pi section ame is friendly name of your pi, mac is unique HW address of your Pi (I look for it in DHCP logs, but there are number of ways to find it). IP address is up to you, you just need to remember it for the future steps.
If we boot Pi now[...] Autoboot in 1 seconds MMC: no card present Device 0: unknown device ethernet@1c30000 Waiting for PHY auto negotiation to complete. done BOOTP broadcast 1 DHCP client bound to address 192.168.1.49 (6 ms) Using ethernet@1c30000 device TFTP from server 192.168.1.2; our IP address is 192.168.1.49 Filename '/pxelinux.0'. Load address: 0x42000000
Both of our settings are accepted, but TFTP server is not responding, that what we're going to fix in next step
Step 2: enable SPI flash and and write u-boot
08/11/2021 at 22:30 • 0 commentsNext step is to flash u-boot (ie bootloader) to SPI flash.
When Pi starts normally first stage bootloader (this one is hard-coded into the CPU itself) will look for boot device. Normally it will find sd-card and boot from it (it has highest priority).
When it is not present however it will try luck with other boot sources, including SPI flash. So it will actually initialize SPI bus all on it's own and look for bootloader there (u-boot in our case). So in this step we will flash it there. Alternatively you may programm SPI flash directly on the Pi, but this is more advanced scenario and it is not covered in this tutorial.
Next steps are run on Pi
$ sudo apt update $ sudo apt upgrade $ sudo apt-get install flashrom
Next we will enable SPI flash to gain access to it (it is disabled by default) by adding device tree layer named spi-spidev
$ sudo nano /boot/armbianEnv.txt
File will look like this after edit
verbosity=1 bootlogo=false console=serial disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=usbhost2 usbhost3 spi-spidev rootdev=UUID=3dbf7aef-312c-456c-a992-e6bde7857d3f rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u param_spidev_spi_bus=0
We reboot after that to confirm presense of SPI device
$ sudo reboot [...] $ ls -l /dev/spi* crw------- 1 root root 153, 0 Aug 11 22:19 /dev/spidev0.0
Device is present, we can start preparing image to flash.
$ mkdir spiflash && cd spiflash # create empty image, ouf flash chip can be larger, but for our purposes it is just enough $ dd if=/dev/zero count=2048 bs=1K | tr '\000' '\377' > spi.img # let's find u-boot binary in the local filesystem $ ls -al /usr/lib/linux-u-boot-*_armhf/*.bin -rw-rw-r-- 1 root root 469855 Aug 8 14:21 /usr/lib/linux-u-boot-current-orangepizero_21.08.1_armhf/u-boot-sunxi-with-spl.bin $ dd if=/usr/lib/linux-u-boot-current-orangepizero_21.08.1_armhf/u-boot-sunxi-with-spl.bin of=spi.img bs=1k conv=notrunc
Now we have an image in spi.img file, that we just need to flash
$ sudo flashrom -p linux_spi:dev=/dev/spidev0.0 -w spi.img -c MX25L1605A/MX25L1606E/MX25L1608E flashrom v1.2 on Linux 5.10.43-sunxi (armv7l) flashrom is free software, get the source code at https://flashrom.org Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns). Using default 2000kHz clock. Use 'spispeed' parameter to override. Found Macronix flash chip "MX25L1605A/MX25L1606E/MX25L1608E" (2048 kB, SPI) on linux_spi. Reading old flash chip contents... done. Erasing and writing flash chip... Erase/write done. Verifying flash... VERIFIED.
Now we're ready to reboot and try out boot without SD-card present
$ sudo poweroff
Upon reboot without SD-card
U-Boot SPL 2020.10-armbian (Aug 08 2021 - 16:21:05 +0200) DRAM: 256 MiB Trying to boot from sunxi SPI U-Boot 2020.10-armbian (Aug 08 2021 - 16:21:05 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... MMC: no card present In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds MMC: no card present Device 0: unknown device ethernet@1c30000 Waiting for PHY auto negotiation to complete. done BOOTP broadcast 1 DHCP client bound to address 192.168.1.202 (8 ms)
What happens above is Pi able to boot from SPI flash, it found no boot media, initialized Ethernet and obtained IP address from DHCP server.
Next step is to configure that DHCP server with right commands for our Pi to boot from.
Step 1: prepare SD-card image, boot, perform initial configuration
08/11/2021 at 21:56 • 0 commentsFirst we would need bootable SD-card. As mentioned before we will use it to (a) flash onboard SPI and (b) take snapshot of the root FS.
1. I'll start with Armbian, later on we might want to take another distro. Go to Armbian website and get latest image, at the moment of writing it is Armbian_21.05.6_Orangepizero_focal_current_5.10.43.img.xz
2. Insert SD card and note its name. It is sdc in my case. No need to mount or format it.
$ lsblk [...] sdc 8:32 1 14,6G 0 disk └─sdc1 8:33 1 14,5G 0 part
3. Flash the image to SD card
$ xz --decompress Armbian_21.05.6_Orangepizero_focal_current_5.10.43.img.xz $ sudo dd if=Armbian_21.05.6_Orangepizero_focal_current_5.10.43.img of=/dev/sdc bs=1M 1144+0 records in 1144+0 records out 1199570944 bytes (1,2 GB, 1,1 GiB) copied, 214,305 s, 5,6 MB/s $sudo sync
Let's boot it and perform initial configuration, like account creation, setting up passwords and whatever else you need to claim it ready for taking snapshot
I'll start screen to monitor boot process via USB-UART adapter by issuing command
$ screen /dev/ttyUSB0 115200
Result is below
U-Boot SPL 2021.04-armbian (Jun 21 2021 - 15:06:33 +0000) DRAM: 256 MiB Trying to boot from MMC1 U-Boot 2021.04-armbian (Jun 21 2021 - 15:06:33 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... [...] [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started Dispatcher daemon for systemd-networkd. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Finished Update UTMP about System Runlevel Changes. orangepizero login: root (automatic login) ___ ____ _ _____ / _ \| _ \(_) |__ /___ _ __ ___ | | | | |_) | | / // _ \ '__/ _ \ | |_| | __/| | / /| __/ | | (_) | \___/|_| |_| /____\___|_| \___/ Welcome to Armbian 21.05.6 Focal with Linux 5.10.43-sunxi System load: 100% Up time: 2 min Memory usage: 47% of 238M IP: CPU temp: 54°C Usage of /: 8% of 15G RX today: n/a [ General system configuration (beta): armbian-config ] New to Armbian? Documentation: https://docs.armbian.com Support: https://forum.armbian.com New root password:
Next step is to enable SPI flash and flash it with u-boot
Introduction
08/11/2021 at 19:38 • 0 commentsRecently I was playing around Orange Pi Zero (actually checking if I'd be able to boot it without any storage). Almost accidentally I found out that recent u-boot able to use onboard Ethernet for boot purposes. Checked everything and it did indeed worked. I want to note my steps for anyone willing to repeat that process.
First of all prerequisites:- Orange Pi Zero - tutorial would not work for just any Orange Pi out there. I'm using onboard SPI flash to start boot process, and per my knowledge only Orange Pi Zero has both SPI flash and Ethernet PHY.
- To configure Orange Pi we need SD card. One finished it will be no longer required. It is not strictly necessary, but makes things easier.
- (optional) To debug whole process it is really helpful to have USB-UART adapter. It will cost you around $1 if you still don't have one. It is not strictly necessary, but will help a lot in understanding the process
From your network perspective
- (A) Some router serving as DHCP server. When Pi will bot it will need clear instruction where boot components should be taken from.
- (B) Some network server with storage, preferably fast one. It will store Pi filesystems
- (C) Some network server with boot artifacts exposed via TFTP server.
All of the above can be combined in single physical machine, or split roles in every possible combination.
From the perspective of going through this tutorial we would need some wokrplace PC or laptop with access to the same network. This is where we're sitting and deploying all the magic.
The process in general will look like this
1. We prepare standard bootable image on SD card and boot it on our Pi. We will need it to (a) flash u-boot to onboard SPI flash and (b) to take filesystem snapshot
2. We will configure NFS (network accessible filesystem) and take snapshot from running system.
3. We will configure TFTP service on network boot server and configure DHCP to instruct our Pi to use it.
Boot process in short:
