Gerber-files and BOM is included in the project.
To program the ESP8266 for the first time, bridge the BOOT jumper and connect a FTDI-cable with a male header pinched in the connector. Then use OTA to update.
This is a PCB for Sören Beye [Hyper] code to piggyback the IKEA Vindrikning sensor in a "clean" way.
IKEA_vindriktning_v2.zipx-zip-compressed - 61.72 kB - 08/12/2021 at 13:28 |
I used your board design, thank you for sharing your work.
Its a tiny bit confusing because you have annotated TXO and RXI on the FTDI connector incorrectly on your schematic. The pins are however in the correct order so it will work.
Hi,
maybe you could add the Connections for a CCS811, a DHT22 and a MH-Z19B or a MQ135 to the PCB ?
Great Project. Is is possible to publish a pick and place File of the Project? in addition to the Gerber data?
Amazing project! So clean! - would it be possible to get the source files? would like to panelize an order, so would be easier to do it!
Do you sell this in tindie, or would you be against someone else selling it?
