Remember when I wrote that I ran out of mistakes to make in this project? Was I ever wrong. The PCBs just came from DirtyPCBs:
That's not the kind of panelization that I expected... Of course I immediately downloaded back the zip file with gerbers and checked it:
Yup, that's what I sent them to make (unless they do some processing to it). Of course I didn't notice a problem, because the preview at DirtyPCBs is broken since they switched to the new website, and doesn't show the board outline.
Now I have a few days of dremeling before me.
deʃhipu
How many of those panels have you got? = About 10 :-)
Maybe a Hacksaw would also work okay :)
BTW: Why did you panelize the PCBs in 5x5cm?
I played around with the calculator and it seems it was the cheapest solution for ~40 PCBs ;-)
But for 20$ you would have got 100 PCBs, if a single PCB is smaller than 20x30mm :-)
Dremel worked well, they are all assembled already. Yes, I was aiming at ~30 boards, because that's how many matrices I have -- they are actually the most expensive part of this. I don't want to be making and selling those in large quantities -- just enough to get other manufacturers interested in this, so that they will start producing it cheaper and with free shipping.
The boards are exactly 25.5x20.4mm.
Great. Thats nice. Thank you for your reply! Have a nice Weekend!
That's why I usually use 0.8mm PCB... They are easy to just score once on each side with a box cutter knife and then just snap apart.
Sure, the pcbs become a little bit more flexible but it's hardly noticeable on a 5x5cm or smaller.
Yeah, but of course I picked 1.6mm here...
See step 1: https://hackaday.io/project/6929-smt-assembly-on-the-cheap
Also: http://www.eevblog.com/forum/eda/clean-way-to-cut-fr4-pcb/
A good snip (bottom right) can do the rough cut for FR4. 2 good pairs of piers would let you snap a much thinner strip of FR4. i do that all the time for trimming size of toner transfer PCB.
Ah, that should be much faster than dremel!
I take that back. It *would* have been faster, if they were straight lines from end to end. However, it's this swastika shape, and the dremel is actually faster for that.
you *could* drill a hole where the groves end to stop the cutting
nice throwing stars :(
Impressive...
I feel for you :-(
