Home security system using the Waylay IO IoT platform and M5Stack modules.
For this tutorial, we have decided to use the M5Stack Ecosystem because it enables building such a system without prototyping specific tools, such as a soldering iron or prototyping cables. The brain of this project is the M5Core2, an IoT development kit based on the ESP32 microcontroller. This ecosystem allows you to connect the provided modules through a GROVE port to the M5Core2, allowing fast deployment of hardware.
The modules we’ve picked for this tutorial are M5Stack’s Ultrasonic Distance Unit and PIR Motion Sensor.
BLACK - GND RED - 5V YELLOW - G36 WHITE - G26
