« Back to project details
#4 Mini Hyperloop Prototype
09/12/2023 at 11:22 • 0 comments -
#3 Control System Development
09/12/2023 at 10:29 • 0 comments -
#2 Final Design
09/12/2023 at 10:23 • 0 commentsOnce the approximate dimensions and the concept were defined, the concept was adapted on the basis of the main limiting components (battery module, electronics - main PCB, track PCB).
From this followed the final design including the development of the electronics:
Tube and Track
Overall View
Front view
Top view
Pod - moving vehicle
The Pod is devided in the capsule, which includes the battery and the moving platform, which includes the levitation system.
T
The levitation system is receives power from the battery via spring contacts. The capsule and moving platform are hold together with magnets, what allows for easy disassembly and charging of the capsule. -
1# Conception and Design
08/22/2021 at 15:02 • 0 comments
