3-axis CNC Milling Machine (UHPC)
Self engineered and build servo driven milling machine
Self engineered and built 3-axis CNC milling machine.
- mineral casting
- selfmade ATC spindle cartrige
- selfmade ATC (parallel kinematic)
- Servo driven on all axis
You can find the full build video here: https://youtu.be/UF9cnJy6K0U
Build video
  • 4# - Spindle head and pneumatic cylinder for ATC
    Adrian Prinz08/25/2021 at 13:46 0 comments
    The spindle head is made of lasered plates and holds the spindle cartridge (old version of the spindle flansh in the picture below)
    Assembled spindel head (old version of the water cooling):
    Spindle belt drive:
    Self engineered pneumatic cylinder for the draw bar:
    All assembled and painted (cylinder fixture is temporary..):
  • 3# Spindle head and X-Y-table
    Adrian Prinz08/23/2021 at 16:27 0 comments
    A belt pulley was adapted to the 2.2 kW Spindle motor (China Spindle - used as motor) to drive the spindle cartridge
    Components for the X-Y-table were machined on the lathe
    Side stiffeners for the z column (lasered plates)
    Assembled Z-axis, side stiffeners and X-Y-table
  • 2# Z-Axis and Spindle
    Adrian Prinz08/22/2021 at 14:47 0 comments
    The back of the Z-Axis was casted in UPH concrete
    At this point i decided to go full in and build up the overall machine from scratch. I designed it in CAD and continued with the Spindle cartridge, since it is the most difficult part.
    Turning the cartridge
    Grinding the cartridge
    Turning the spindle shaft
    Machining the draw bar
    Finished draw bar (hardend to about 54 HRC - C45k)
    Spindle watercooling mandrel
    Finished spindle cartridge (after some iterations.. :) )
    Assembled in the spindle holder
  • 1# Base material and first parts - project idea
    Adrian Prinz08/22/2021 at 14:31 0 comments
    Without the actual intention to build this machine at the beginning, I started of with random cut offs from ebay. (Just planed to improve my former CNC milling machine)
    I cut the components roughly to length..
    First I  used the bench top lathe (that was borrowed to me for a different project :) ) to get the dimensions of the parts on point
    First finished parts...
    Critical dimensions (bearing seats) were machined on the bench top lathe
    All components were machined just by using basic tools and the bench top lathe - no milling machine involved :)
    Test fit of the components..
View all 4 project logs
Rinar wrote 01/12/2025 at 19:58 point
A marvel of engineering and very pleasing to the eye. I'm almost jealous☺️
JoshuaDHay wrote 01/24/2023 at 01:08 point
What was the cost of this, if you don't mind me asking…this has great build quality and in my opinion it is worth as much as the commercial products! Great work and have fun making! :)
Adrian Prinz wrote 06/03/2023 at 16:37 point
Thank you! The overall cost, excluding the servo system, was around 1.5k Euro. The servos doubled that :)
Jörg Schnur wrote 08/26/2021 at 13:48 point
Great project, I admire the hight quality of the results. It motivates me to build similar things.
Adrian Prinz wrote 08/26/2021 at 15:34 point
Thank you - I appreciate it! Glad to hear this, that's the reason why I share it :)
Dan Maloney wrote 08/18/2021 at 22:17 point
Phenomenal build quality! I'd love to see a build log for this one.
Adrian Prinz wrote 08/19/2021 at 16:17 point
Thank you! Good point, I will add a few pictures to the log :)
