Addendum To Log# 62 - Updated C/C++ code for TCD1304 CCD driver circuit
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 02/27/2017 at 00:130 Comments
#include <util/delay_basic.h>
#define RD (1<<2)
#define CNVST (1<<3)
#define BYTESWAP (1<<4)
#define ICG (1<<5)
#define SH (1<<6)
#define MCLK (1<<7)
// Full frame, including dark pixels
// and dead pixels.
#define PIXEL_COUNT 3694
#define CLOCKS PORTD
#define CLOCKP PIND
#define CLOCKS_DDR DDRD
#define DATA_PINS PINC
#define DATA_PORT PORTC
#define DATA_DDR DDRC
// 1mS exposure time.
#define EXPOSURE_TIME 10
// Initial clock state.
uint8_t clocks0 = (RD + CNVST + ICG);
// 16-bit pixel buffer
uint16_t pixBuf[PIXEL_COUNT];
char cmdBuffer[16];
int cmdIndex;
int exposureTime = EXPOSURE_TIME;
int cmdRecvd = 0;
* readLine() Reads all pixels into a buffer.
void readLine() {
// Get an 8-bit pointer to the 16-bit buffer.
uint8_t *buf = (uint8_t *) pixBuf;
int x = 0;
uint8_t scratch = 0;
// Disable interrupts or the timer will get us.
cli();
// Synchronize with MCLK and
// set ICG low and SH high.
scratch = CLOCKS;
scratch &= ~ICG;
scratch |= SH;
while(!(CLOCKP & MCLK));
while((CLOCKP & MCLK));
TCNT2 = 0;
_delay_loop_1(1);
__asm__("nop");
__asm__("nop");
__asm__("nop");
__asm__("nop");
__asm__("nop");
CLOCKS = scratch;
// Wait the remainder of 4uS @ 20MHz.
_delay_loop_1(22);
__asm__("nop");
__asm__("nop");
// Set SH low.
CLOCKS ^= SH;
// Wait the reaminder of 4uS.
_delay_loop_1(23);
// Start the readout loop at the first pixel.
CLOCKS |= (RD + CNVST + ICG + BYTESWAP + SH);
__asm__("nop");
do {
// Wait a minimum of 250nS for acquisition.
_delay_loop_1(2);
// Start the conversion.
CLOCKS &= ~CNVST;
CLOCKS |= CNVST;
// Wait a minimum of 1uS for conversion.
_delay_loop_1(6);
// Read the low byte of the result.
CLOCKS &= ~RD;
_delay_loop_1(3);
__asm__("nop");
__asm__("nop");
*buf++ = DATA_PINS;
// Setup and read the high byte.
CLOCKS &= ~(BYTESWAP);
_delay_loop_1(3);
__asm__("nop");
*buf++ = DATA_PINS;
// Set the clocks back to idle state
CLOCKS |= (RD + BYTESWAP);
// Toggle SH for the next pixel.
CLOCKS ^= SH;
} while (++x < PIXEL_COUNT);
sei();
* clearLine() Clears the CCD.
void clearLine() {
int x = 0;
// Set ICG low.
CLOCKS &= ~ICG;
CLOCKS |= SH;
_delay_loop_1(14);
// Set SH low.
CLOCKS ^= SH;
_delay_loop_1(10);
// Reset the timer so the edges line up.
TCNT2 = 0;
CLOCKS |= (RD + CNVST + ICG + BYTESWAP + MCLK);
do {
CLOCKS ^= SH;
_delay_loop_1(10);
* sendLine() Send the line of pixels to the user.
void sendLine() {
uint16_t x;
for (x = 0; x < PIXEL_COUNT; ++x) {
Serial.print(x);
Serial.print(",");
Serial.print(pixBuf[x]);
Serial.print("\n");
* setup()
* Set the data port to input.
* Set the clock port to output.
* Start timer2 generating the Mclk signal
void setup() {
CLOCKS_DDR = 0xff;
CLOCKS = clocks0;
DATA_DDR = 0x0;
Serial.begin(115200);
// Setup timer2 to generate a 667kHz frequency on D10
TCCR2A = (0 << COM2A1) | (1 << COM2A0) | (1 << WGM21) | (0 << WGM20);
TCCR2B = (0 << WGM22) | (1 << CS20);
OCR2A = 8;
TCNT2 = 0;
* loop()
* Read the CCD continuously.
* Upload to user on switch press.
void loop() {
int x;
char ch;
// If we got a command last time, execute it now.
if (cmdRecvd) {
if (cmdBuffer[0] == 'r') {
// Send the readout to the host.
sendLine();
} else if (cmdBuffer[0] == 'e') {
// Set the exposure time.
sscanf(cmdBuffer + 1, "%d", &exposureTime);
if (exposureTime > 1000) exposureTime = 1000;
if (exposureTime < 0) exposureTime = 0;
// Get ready for the next command.
memset(cmdBuffer, 0, sizeof(cmdBuffer));
cmdIndex = 0;
cmdRecvd = 0;
// Clear the CCD.
clearLine();
// Integrate.
delay(exposureTime);
// Read it for real.
readLine();
// See if the host is talking to us.
if (Serial.available()) {
ch = Serial.read();
// If char is linefeed, it is end of command.
if (ch == 0x0a) {
cmdBuffer[cmdIndex++] = '\0';
cmdRecvd = 1;
// Otherwise it is a command character.
} else {
cmdBuffer[cmdIndex++] = ch;
cmdRecvd = 0;
