Advantages of BrainFlow:
- powerful API with many features to simplify development
- Straightforward API for data acquisition
- Powerful API for signal filtering, denoising, downsampling...
- Development tools like Synthetic board, Streaming board, logging API
- easy to use
- BrainFlow has many bindings, you can choose a programming language you like
- All programming languages provide the same API, so it's simple to switch
- API is uniform for all boards, it makes applications on top of BrainFlow almost board agnostic
- easy to support and extend
- Code to read data and to perform signal processing is implemented only once in C/C++, bindings just call C/C++ methods
- Powerful CI/CD system which runs integrations tests for each commit automatically using BrainFlow's Emulator
- Simplified process to add new boards and methods
Andrey Parfenov
DARK-labs
Tomasz
Stephen Moody
Konrad Beckmann
