SH1106 OLED Now Supported on XIAO & QT-PY aka ATSAMD21
12/28/2021 at 02:14 • 0 commentsAdafruit SH1106 ATSAMD Compatible Library
https://github.com/adafruit/Adafruit_SH110x
Seeed Studio SAMD21 MCU: https://www.seeedstudio.com/Seeeduino-XIAO-Arduino-Microcontroller-SAMD21-Cortex-M0+-p-4426.html
Gnat-Stats OLED Dimming
09/10/2021 at 16:45 • 0 commentsAdded OLED 50% dimming option.
Enable auto-start on system log-in
08/22/2021 at 20:04 • 0 commentsTo enable auto-start on system log-in
Locate HardwareSerialMonitor executable> Right-Click> Properties> Compatibility> Run this program as Admin [X]
Start Menu > Search for "Task Scheduler"
Create Task
General Tab:Name: Whatever you like
[X]: Run only when user is logged on
[X]: Run with highest privileges
Select: Configure for: Windows 10
Triggers Tab> New:Begin the task, Select: At log on
[X]: Specific User:
Actions Tab> New:Action, Select: "Start a program"
Program/script: > Browse the HardwareSerialMonitor.exe
Conditions Tab:
[optional] Disable "Start the task only if the computer is on AC power"
Settings Tab:
To Enable, [X] : "Allow task to be run on demand"
To Disable, [X] : "Stop the task if it runs longer than"
Gnat-Stats OLED Enclosure Prototype
08/22/2021 at 17:39 • 0 comments![]()
Gnat-Stats Concept SSD1306 OLED Enclosure
08/22/2021 at 17:37 • 0 comments![]()
Gnat-Stats (OLED) Hook Up Guides
08/22/2021 at 17:31 • 0 comments
