mutantC V4 - Easy to Build, Modular Handheld PC
A small Handheld PC with a physical 56 key keyboard, 4inch Display and Expansion header for add-on boards (Like Arduino Shield).
So little parts needed to make one. The cost is low. The priciest thing is the LCD and Pi. Now see some key features from mutantC Handheld-
* It is fully open-source hardware. So you can Hack it as you wish.
* 4 icnh IPS display, upto 4GB RAM, 2 HDMI out.
* Has native Serial and Ethernet port.
* 56 key customizable keyboard, 2 shoulder button for navigation.
* Have RTC, Buzzer, Vibration, LDR and IR Transmitter.
* Control your home appliances using mutant's IR Transmitter.
* Auto turn off Display when Display is covered, like when mutanC is on your pocket.
* Add Add-ons to get more features & functionality, see all from HERE.
* ThumbStick to have mouse support with left, right buttons.
* Gyro support using MPU6050 module or Pressure or Temp and Humidity support using BME280 module.
* Able to poweroff modules, Display, Add-ons using keyboard button.
* Full poweroff using OS and keyboard key.
* USB_C form factor Nurolink/docking port with U
You can see there is a list in the PCB, that points to some blocks. Each blocks give you one/ multipal features. So if you want a feature that you want, just solder all the parts in that block. Here is the list of the blocks
Blocks Name Feature Priority
S-1 Main Power Switch Ability to turn on/ off the device Must
S-2 Continuous Charging It prevents device the reboot when you disconnect the charger Optional
S-3 Boost & Charge It boost the battery voltage to 5v Must
S-4 Esp32-s2 + Reset Controls everything in the device Must
S-5 Vibration Give vibration feedback Optional
S-6 Real Time Clock Keeps the time when device is powered off Optional
S-7 MP6050/BME280 Can use Gyro or see Pressure, Temp and Humidity Optional
S-8 Expansion Power Switch Can turn off display, expansion and the modules in S-7 block Optional
S-9 IR Transmitter Using IR mutantC can act as a TV, AC remote Optional
Here I Made 2 version that I think fits either of you if you are a Pro or a Newbie. See this comparison table to select which one you want to build. I will highly recommend building the Lite one as it requires less parts and time to build and you will miss a little of the features. And later on you can add you can also do your own custom build by selecting the features you want on top the Lite version.
Features Lite Regular
Parts List Parts_list Parts_list
56 key keyboard Yes Yes
Battery Life 8 hours 8 hours
Notification LED No Yes
Real Time Clock No Yes
Battery Monitor No Yes
LDR, Vibration, Buzzer No Yes
IR Transmitter No Yes
Gyro/ Pressure, Temp and Humidity No Yes
Poweroff modules, Display, Add-ons No Yes
Nurolink/ Docking port No Yes
Continuous Charging No Yes
View all 2 project logs
Rich text editor
13lenar wrote 01/13/2024 at 20:14 point
My dream is to build something like this, inspired by the Nokia Communicator
JVS wrote 10/09/2021 at 19:56 point
The keyboard doesnt seem that "easy" hehe, anyway have you consider making a new version with the CM4? would be considerably more compact
rahmanshaber wrote 10/11/2021 at 02:42 point
yes, v5 will use a cm4 hopefully.
