Somewhere in the build instructions for the hardware part of this project I was also discussing how I am working on fixing up a sub-dialect of the programming language LISP that i actually developed, something like 25 years or so ago, as a part of a chat bot engine. Well, in any case - I did some updates today to the codebase which is now (at least in part) on GitHub, so this would seem like just as good of a time as any to discuss the role of LISP, in the C++ port of Propeller Debug Terminal.
Basically, the debug terminal responds to a set of commands that can be embedded in a text stream that ideally runs in a side channel alongside the regular printf/scanf I/O semantics that a "normal" ANSI C program might make use of when running in a terminal mode. Hence the command set looks something like this, and that is why LISP is so nice, even if it is written in C++, because at the end of the day it would be so nice to be able to simply CONS a symbol table, and then MAPCAR the symbol table onto a list of GUI commands, so that command processing can be done by tokenizing the input stream and generating the appropriate callbacks or messages.
char *command_proc::debug_tokens[] =
"SCOPE","SCOPE_XY","SCOPE_RT","PLOT","TERM","TITLE","POS","SIZE",
"RANGE","OFFSET","SAMPLES","TRIGGER","LABEL","COLOR","BACKCOLOR",
"GRIDCOLOR","DOTSIZE","LOGSCALE","CLEAR","SAVE","UPDATE","LINESIZE",
"LINECOLOR","FILLCOLOR","TO","RECT","RECTFILL","OVAL","OVALFILL",
"POLY","POLYFILL","TEXTSIZE","TEXTCOLOR","TEXTSTYLE","TEXT",NULL
void command_proc::reset_debug_symbols()
command_proc pdbg;
frame &f = *(pFrame->get());
symbol_table *t=NULL;
t = f.cons(command_proc::debug_tokens)->sort();
pdbg.exec(NULL1);
So this is a screenshot of the raw debugging stream coming from the P2 chip while running a four-channel oscilloscope program, and the hexadecimal data is oscilloscope data being streamed live. It is just not being plotted .just yet. Real soon now.
glgorman
