In this project we will create a neural network with Python and copy its weights to a network with forward propagation on the Arduino UNO board, and that will allow the Autonomous Robot to drive alone and without hitting the walls.
For this exercise we will make the neural network have 4 outputs: two for each motor pair, since to the L298N driver we will connect 2 digital outputs of the board for each car motor pair (the two motors on the left are electrically linked, the same case with the two motors on the right.). In addition the outputs will be between 0 and 1 (depolarize or polarize the motor).
Neural Networks
We will have seven inputs:
- First input is the activation of the Autonomous Robot that we saw on section 4 (Second case of Alexa's voice commands).
- The next five inputs correspond to the infrared and ultrasound sensors; and
- The seventh input is for the BIAS, the values will be 0 and 1.
The inputs are assigned with the following logic:
- The GP2Y0A51SK0F IR sensors on the left and right sides will have a value of 1 if the distance is less than 15 cm, and will have a value of 0 if the distance is greater than 15 cm;
- The GP2Y0A41SK0F IR center sensor will have a value of 1 if the distance is less than 30 cm, and will have a value of 0 if the distance is greater than 30 cm;
- The same case, HC-SR04 and the SRF05 ultrasound sensors will have a value of 1 if the distance is less than 30 cm, and will have a value of 0 if the distance is greater than 30 cm; and
- The BIAS will have a value of 1.
Here we see the changes in the table below:
Inputs, Outputs and Actions of the Gearmotors
To create our neural network, we will use this code developed with Python 3.7.3: neural-network.py
import numpy as np
# We create the class
def __init__(self, layers, activation='tanh'):
if activation == 'sigmoid':
self.activation = sigmoid
self.activation_prime = sigmoid_derivada
elif activation == 'tanh':
self.activation = tanh
self.activation_prime = tanh_derivada
# Assign random values to input layer and hidden layer
for i in range(1, len(layers) - 1):
r = 2*np.random.random((layers[i-1] + 1, layers[i] + 1)) -1
self.weights.append(r)
# Assigned random to output layer
r = 2*np.random.random( (layers[i] + 1, layers[i+1])) - 1
def fit(self, X, y, learning_rate=0.2, epochs=100000):
# I add column of ones to the X inputs. With this we add the Bias unit to the input layer
ones = np.atleast_2d(np.ones(X.shape[0]))
X = np.concatenate((ones.T, X), axis=1)
for k in range(epochs):
i = np.random.randint(X.shape[0])
a = [X[i]]
for l in range(len(self.weights)):
dot_value = np.dot(a[l], self.weights[l])
activation = self.activation(dot_value)
a.append(activation)
#Calculate the difference in the output layer and the value obtained
error = y[i] - a[-1]
deltas = [error * self.activation_prime(a[-1])]
# We start in the second layer until the last one (A layer before the output one)
for l in range(len(a) - 2, 0, -1):
deltas.append(deltas[-1].dot(self.weights[l].T)*self.activation_prime(a[l]))
self.deltas.append(deltas)
# Reverse
deltas.reverse()
# Backpropagation
# 1. Multiply the output delta with the input activations to obtain the weight gradient.
# 2. Updated the weight by subtracting a percentage of the gradient
for i in range(len(self.weights)):
layer = np.atleast_2d(a[i])
delta = np.atleast_2d(deltas[i])
self.weights[i] += learning_rate * layer.T.dot(delta)
def predict(self, x):
ones = np.atleast_2d(np.ones(x.shape[0]))
a = np.concatenate((np.ones(1).T, np.array(x)), axis=0)
for l in range(0, len(self.weights)):
a = self.activation(np.dot(a, self.weights[l]))
return a
def print_weights(self):
print("LIST OF CONNECTION WEIGHTS")
print(self.weights[i])
def get_weights(self):
return self.weights
def get_deltas(self):
return self.deltas
# When creating the network, we can choose between using the sigmoid or tanh function
def sigmoid(x):
return 1.0/(1.0 + np.exp(-x))
def sigmoid_derivada(x):
return sigmoid(x)*(1.0-sigmoid(x))
def tanh_derivada(x):
return 1.0 - x**2
########## CAR NETWORK
nn = NeuralNetwork([6,3,4],activation ='tanh')
X = np.array([[0,0,0,0,0,0],
[0,0,0,0,0,1],
[0,0,0,0,1,0],
[0,0,0,0,1,1],
[0,0,0,1,0,0],
[0,0,0,1,0,1],
[0,0,0,1,1,0],
[0,0,0,1,1,1],
[0,0,1,0,0,0],
[0,0,1,0,0,1],
[0,0,1,0,1,1],
[0,0,1,1,0,0],
[0,0,1,1,0,1],
[0,0,1,1,1,1],
[0,1,0,0,0,0],
[0,1,0,0,0,1],
[0,1,0,0,1,0],
[0,1,0,1,0,0],
[0,1,0,1,0,1],
[0,1,0,1,1,0],
[0,1,1,0,0,0],
[0,1,1,0,1,0],
[0,1,1,1,0,0],
[0,1,1,1,1,0],
[1,0,0,0,0,0],
[1,0,0,0,0,1],
[1,0,0,0,1,0],
[1,0,0,0,1,1],
[1,0,0,1,0,0],
[1,0,0,1,0,1],
[1,0,0,1,1,0],
[1,0,0,1,1,1],
[1,0,1,0,0,0],
[1,0,1,0,0,1],
[1,0,1,0,1,1],
[1,0,1,1,0,0],
[1,0,1,1,0,1],
[1,0,1,1,1,1],
[1,1,0,0,0,0],
[1,1,0,0,0,1],
[1,1,0,0,1,0],
[1,1,0,1,0,0],
[1,1,0,1,0,1],
[1,1,0,1,1,0],
[1,1,1,0,0,0],
[1,1,1,0,1,0],
[1,1,1,1,0,0],
[1,1,1,1,1,0],
# the outputs correspond to starting (or not) the motors
y = np.array([[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[0,0,0,0], # stop
[1,0,1,0], # forward
[0,1,1,0], # turn-left
[0,1,0,1], # back
[1,0,0,1], # turn-right
[0,1,0,1], # back
nn.fit(X, y, learning_rate=0.03,epochs=550001)
def valNN(x):
return (int)(abs(round(x)))
index=0
for e in X:
prediccion = nn.predict(e)
print("X:",e,"expected:",y[index],"obtained:", valNN(prediccion[0]),valNN(prediccion[1]),valNN(prediccion[2]),valNN(prediccion[3]))
index=index+1
We can see the next data:
Expected and obtained values with this code
The code we add to see the graph, as it trains after 550,000 iterations is as follows: graphic.py
########## WE GRAPH THE COST FUNCTION
import matplotlib.pyplot as plt
deltas = nn.get_deltas()
valores=[]
index=0
index=index+1
plt.plot(range(len(valores)), valores, color='b')
plt.ylim([0, 1])
plt.ylabel('Cost')
plt.xlabel('Epochs')
plt.tight_layout()
plt.show()
And now we can see the weights obtained from the connections, and which will be the ones we will use in the Arduino code: generate-arduino-code.py
########## WE GENERATE THE ARDUINO CODE
def to_str(name, W):
s = str(W.tolist()).replace('[', '{').replace(']', '}')
return 'float '+name+'['+str(W.shape[0])+']['+str(W.shape[1])+'] = ' + s + ';'
# We get the weights trained to be able to use them in the arduino code
print('// Replace these lines in your arduino code:')
print('// float HiddenWeights ...')
print('// float OutputWeights ...')
print('// With trained weights.')
print('\n')
print(to_str('HiddenWeights', pesos[0]))
print(to_str('OutputWeights', pesos[1]))
The Arduino code with the configuration of the neural network is loaded on the Arduino UNO board: autonomous-robot.ino
// AUTHOR: GUILLERMO PEREZ GUILLEN
#define ENA 3
#define ENB 5
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
NETWORK CONFIGURATION
const int ESP32_pin_1= 6; // ESP32 input pin 1 - starting
const int ESP32_pin_2 = 7; // ESP32 input pin 2 - SRF04
const int ESP32_pin_3 = 12; // ESP32 input pin 3 - SRF05
const int InputNodes = 7; // includes BIAS neuron
const int HiddenNodes = 4; //includes BIAS neuron
const int OutputNodes = 4;
int i, j;
float HiddenWeights[7][4] = {{-4.618963658666277, 4.3001137618883325, 7.338055706191847, 2.7355309007172375}, {2.599633307446623, -7.649705724376986, -14.69443684121685, -3.65366992422193}, {-0.7777191662679982, 1.9860139431844053, 5.914809078303235, 0.03170277380327093}, {-2.309653145069323, 6.8379997039119775, 8.892299055796917, 0.6046238076393062}, {1.3276547120093833, 5.085574619860947, 2.384944264717347, 0.05753178068519734}, {-2.7696264005599858, 6.797226565794283, 3.5374247269984713, 0.5475825968169957}, {0.8118152131237218, -1.9324229493484606, -5.264294920291424, -0.036800281071245555}};
float OutputWeights[4][4] = {{-1.6342640637903814, 0.006920937706630823, -5.179205882976105, -0.40268984302793936}, {-1.0162353344988182, 1.3405072244655225, -4.241619375014734, 0.6682851389512594}, {1.3692632942485174, -1.3884291338648505, -0.9245235380688354, 2.246128813012694}, {-1.9802299382328057, 0.06512857708456388, -0.030302930346753857, -3.314024844617794}};
int error=0;
int dif,difAnt=0;
const float Kp=0.5671;
const float Kd=110.1;
void setup() {
Serial.begin(9600);
pinMode(A0, INPUT); //left sensor
pinMode(A1, INPUT); //center sensor
pinMode(A3, INPUT); //right sensor
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(ESP32_pin_1, INPUT);
pinMode(ESP32_pin_2, INPUT);
pinMode(ESP32_pin_3, INPUT);
void loop()
double TestInput[] = {0, 0, 0};
double input1=0,input2=0,input3=0,input4=0,input5=0,input6=0;
float volts0 = analogRead(A0)*0.0048828125; // value from sensor * (5/1024)
float volts1 = analogRead(A1)*0.0048828125; // value from sensor * (5/1024)
float volts2 = analogRead(A3)*0.0048828125; // value from sensor * (5/1024)
dif = analogRead(A3) - analogRead(A0); // PID CONTROLLER
error = floor(Kp*(dif)+Kd*(difAnt-dif)); // PID CONTROLLER
difAnt=dif; // PID CONTROLLER
int d0 = constrain(150 - error, 0, 150);//left speed - PID CONTROLLER
float ir_sensor_left = 6*pow(volts0, -1); // worked out from datasheet graph //GP2Y0A51SK0F - 2 a 15 cm
float ir_sensor_center = 12.4*pow(volts1, -1); // worked out from datasheet graph //GP2Y0A41SK0F - 4 a 30 cm
float ir_sensor_right = 5.2*pow(volts2, -1); // worked out from datasheet graph //GP2Y0A51SK0F - 2 a 15 cm
if (ir_sensor_left<15){input2=1;} // IR SENSOR LEFT
else {input2=0;}
if(digitalRead(ESP32_pin_2) == HIGH){input3=1;} // RF SENSOR LEFT
else {input3=0;}
if (ir_sensor_center<30){input4=1;} // IR SENSOR CENTER
else {input4=0;}
if(digitalRead(ESP32_pin_3) == HIGH){input5=1;} // RF SENSOR RIGHT
else {input5=0;}
if (ir_sensor_right<15){input6=1;} // IR SENSOR RIGHT
else {input6=0;}
WE CALL THE FEEDFORWARD NETWORK WITH THE INPUTS
Serial.print("Input1:");
Serial.println(input1);
Serial.print("Input2:");
Serial.println(input2);
Serial.print("Input3:");
Serial.println(input3);
Serial.print("Input4:");
Serial.println(input4);
Serial.print("Input5:");
Serial.println(input5);
Serial.print("Input6:");
Serial.println(input6);
Serial.println(" ");
//THESE ARE THE THREE INPUTS WITH VALUES OF 0 TO 1 ********************
TestInput[0] = 1.0;//BIAS UNIT
TestInput[1] = input1;
TestInput[2] = input2;
TestInput[3] = input3;
TestInput[4] = input4;
TestInput[5] = input5;
TestInput[6] = input6;
// THIS FUNCTION IS TO GET THE OUTPUTS **********************************
InputToOutput(TestInput[0], TestInput[1], TestInput[2], TestInput[3], TestInput[4], TestInput[5], TestInput[6]); //INPUT to ANN to obtain OUTPUT
int out1 = round(abs(Output[0]));
int out2 = round(abs(Output[1]));
int out3 = round(abs(Output[2]));
int out4 = round(abs(Output[3]));
Serial.print("Output1:");
Serial.println(out1);
Serial.print("Output2:");
Serial.println(out2);
Serial.print("Output3:");
Serial.println(out3);
DRIVE MOTORS WITH THE NETWORK OUTPUT
analogWrite(ENA, d0);
analogWrite(ENB, d1);
digitalWrite(IN1, out1 * HIGH);
digitalWrite(IN2, out2 * HIGH);
digitalWrite(IN3, out3 * HIGH);
digitalWrite(IN4, out4 * HIGH);
delay(20);
void InputToOutput(double In1, double In2, double In3, double In4, double In5, double In6, double In7)
double TestInput[] = {0, 0, 0, 0, 0, 0, 0, 0};
TestInput[0] = In1;
TestInput[1] = In2;
TestInput[2] = In3;
TestInput[3] = In4;
TestInput[4] = In5;
TestInput[5] = In6;
TestInput[6] = In7;
CALCULATE ACTIVITIES IN HIDDEN LAYERS
for ( i = 0 ; i < HiddenNodes ; i++ ) { // We go through the four columns of the hidden weights
Accum = 0;
for ( j = 0 ; j < InputNodes ; j++ ) { // Three values of the entry line and each column of hidden weights
Accum += TestInput[j] * HiddenWeights[j][i] ;
Hidden[i] = tanh(Accum) ; // We obtain a matrix of a line with four values
Guillermo Perez Guillen
