This project represents my submission for the Hackaday Prize 2021! Now in the 3rd iteration stage, the ball drone has not only become safer and more efficient, it now also supports more features and potential areas of application. With its thrust vector control and the use of only one propeller, it significantly shifts the limits of the classic and widespread implementation of a drone and triggers "redefine robots".
Equipped with GPS, sensors and light, this design is unique, scalable and the area of application is unimaginably large! From toys to a measuring drone for fine dust to light and signal drones in the event of emergency.
Compared to the MK II, the newly designed housing virtually eliminates touching moving parts and also increases the efficiency of the system. This is not a racing drone, but everything else!
Details
New stuff is around. I am going to publish new stuff and more details from 08/30 on
Updates are definitely coming! I actually wanted to push the project for this year's Hackaday Prize, but unfortunately I was so busy that I didn't have time to continue working on it.
is it possible to share the stl files ?
