1Upload the model
You can use any software to edit the cap before printing. But Tinkercad is just enough for this purpose and fast to edit.
2SVG file
Use any vector software to export and svg file and upload it to Tinkercad, you can create a hollow shape with this svg file. 1mm is enough.
33D Printing
For 3D printing you will need to set layer height a 0.2mm maximum to get a good resolution on the thread part of the cap.
4Disassemble the Binder Clip
Disassemble the arm of the binder clip and put it inside the cap.
DSLR DIY
