1Introduction
In the recent years, air pollution has been a growing concern for the harmful effects it has on our environment. The problem is prevailing particularly in urban cities because of the increased traffic and a wide array of industries which produce a lot of harmful gases as a bi-product of manufacturing. Apart from this, indoor air pollution is also a great concern in metro cities. According to research, the air inside our house is even more polluted compared to the air in outdoor environments.
Hence, a number of countries have already taken preventive measures and setup various air and weather quality monitoring systems in the popular destinations of their big cities so that they can obtain the data and take the necessary steps to prevent the adverse effects of air pollution. But there are several problems with the present systems. Firstly, these systems use the primitive methods which includes collecting air samples and get them tested in a laboratory and even though this methodology is reliable, it is highly ineffective and very expensive (the laboratory equipment). Secondly, there is no system yet created to address the issue of indoor air pollution which has a harmful effect on the health of a great number of individuals every year. So, it is of utmost importance to develop an advanced system which can overcome the above drawbacks.
2Get PCBs for Your Projects Manufactured
You must check out PCBWAY for ordering PCBs online for cheap!
You get 10 good-quality PCBs manufactured and shipped to your doorstep for cheap. You will also get a discount on shipping on your first order. Upload your Gerber files onto PCBWAY to get them manufactured with good quality and quick turnaround time. Check out their online Gerber viewer function. PCBWAY takes care of its customers a lot that's why they offer reward points with every purchase that you make from them these reward points can be redeemed for various useful items from their gift shop.
3So, what is the Solution?? This Project!!
This projectpresents a real-time and long-range air pollution monitoring system for indoor and outdoor environments. The system implemented a wireless sensor network using LoraWAN technology for data communication between all nodes and sensors. The system consists of two nodes distributed within 1 Km distance to gateway for measuring the concentration of VOCs (Volatile Organic Compounds), carbon dioxide andPM2.5 (Particulate Matter 2.5um) readings. Experimental results show the system is reliable in both indoor and outdoor applications. The distance coverage achieved up to 900m and can be displayed through a web-based client (Thingspeak) and also from an Android or iOS application. The experiment with LoraWAN transmission has shown that the LoraWAN technology is very suitable for the air pollution system especially in long range transmission compared to other wireless transmission techniques and the power consumption of the system is also considerably lower than the existing systems and also some actuation techniques would be discussed and demonstrated
4Important Note
Even though this project is not created using the Helium Network or Console, it is very easy to migrate from the platform we will be using now.
I would like to request the judges to regard this submission as I tried for almost 2 months to setup an Helium hotspot in India, but nothing I did worked. I even tried creating my own Hotspot but I had no luck there too. Finally, I picked up a generic LoRa Gateway and created my whole project on the Indian Lora sub band of 865-867 Mhz. I would again like to apologize for not using the provided Hardware for this project but I assure you that I will be using it for my future projects once the Helium Network support comes to India.
But this project can be easily migrated to any platform of our choice and so I will also cover the Helium console setup and setting up the Helium Miner in this project. So, let's get started with the Hardware and software requirements of this project.
5Hardware Components of the Project
LG01N Single Channel LoRa Gateway by Dragino
LG01-N is an open source single channel LoRa Gateway. It lets you bridge LoRa wireless network to an IP network via Wi-Fi, Ethernet, Or 3G/4G cellular via optional LTE module. TheLoRa wireless allows users to send data and reach extremely long ranges at low data-rates. It provides ultra-long range spread spectrum communication and high interference immunity. LG01-N has rich internet connection method such as Wi-Fi interface, Ethernet port and USB host port.
LG01-N can support Limited LoraWAN protocol in single frequency and customized LoRa transmit protocol. Different from LG01-P/LG01-S, LG01-N use the Linux to directly control the sx1276/sx1278 LoRa module which increase the communication efficiency and simplify the software design.
Dragino Lora Shield for Arduino v1.4 (EU868)
LoRa Shield is a long-range transceiver on an Arduino shield form factor and based on Open source library. The Shield allows the user to send data and reach extremely long ranges at low data-rates. It provides ultra-long range spread spectrum communication and high interference immunity whilst minimizing current consumption.
LoRa Shield is based on Semtech SX1276/SX1278 chip, it targets professional wireless sensor network applications such as irrigation systems, smart metering, smart cities, smartphone detection, and so on.
Features:
- Compatible with 3.3v or 5v I/O Arduino Board.
- Frequency Band: 915MHz/868 MHZ/433 MHZ (Pre-configure in factory)
- Low power consumption
- Compatible with Arduino Leonardo, Uno, Mega, DUE
- External Antenna via I-Pex connector
CCS811 Ultra Low Power Digital Gas Sensor
The CCS811 is an ultra-low power digital gas sensor solution which integrates a metal oxide (MOX) gas sensor to detect a wide range of Volatile Organic Compounds (VOCs) for indoor air quality monitoring with a microcontroller unit (MCU), which includes an Analog-to-Digital converter (ADC), and an I²C interface.
CCS811 is based on ams unique micro-hotplate technology which enables a highly reliable solution for gas sensors, very fast cycle times and a significant reduction in average power consumption. The integrated MCU manages the sensor drive modes and raw sensor data measured while detecting VOCs. The I²C digital interface significantly simplifies the hardware and software design, enabling a faster time to market.
CCS811 supports intelligent algorithms to process raw sensor measurements to output a TVOC value or equivalent CO2 (eCO2) levels, where the main cause of VOCs is from humans. CCS811 supports multiple measurement modes that have been optimized for low-power consumption during an active sensor measurement and idle mode extending battery life in portable applications.
Modes of Operation
The CCS811 has 5 modes of operation as follows
- Mode 0: Idle, low current mode
- Mode 1: Constant power mode, IAQ measurement every second
- Mode 2: Pulse heating mode IAQ measurement every 10 seconds
- Mode 3: Low power pulse heating mode IAQ measurement every 60 seconds
- Mode 4: Constant power mode, sensor measurement every 250ms
MICS – 5524 Gas Sensor Module
This breakout makes it easy to use this nice sensor from SGX Sensortech. The MiCS-5524 is a robust MEMS sensor for indoor carbon monoxide and natural gas leakage detection, it's suitable also for indoor air quality monitoring; breath checker and early fire detection.
Please note: This sensor is sensitive to CO (~ 1 to 1000 ppm), Ammonia (~ 1 to 500 ppm), Ethanol (~ 10 to 500 ppm), H2 (~ 1 - 1000 ppm), and Methane / Propane / Iso-Butane (~ 1, 000++ ppm). However, it can't tell you which gas it has detected.
PM2.5 GP2Y1010AU0F Dust Smoke Particle Sensor
This PM2.5 GP2Y1010AU0F Dust Smoke Particle Sensor is an infrared emitting diode (IRED) and a phototransistor are diagonally arranged into this device. It detects the reflected light of dust in the air. Especially, it is effective to detect very fine particle like the cigarette smoke. In addition, it can distinguish smoke from house dust by the pulse pattern of the output voltage.
The module is mainly used for dust removal equipment alarm equipment, air purification equipment, dust robots, fire alarm, etc. industry equipment can detect smoke particles, pollen spores, and other particles.
Raspberry Pi
The Raspberry Pi is a series of small single-board computers developed in the United Kingdom by the Raspberry Pi Foundation to promote teaching of basic computer science in schools and in developing countries. The original model became far more popular than anticipated, selling outside its target market for uses such as robotics. It now is widely used even in research projects, such as for weather monitoring, because of its low-cost and portability. It does not include peripherals (such as keyboards and mice) or cases.
We will be using the Pi just to create a Home visualization and control system which would allow us to view our sensor data on a Dashboard.
6Software Components of the Project
The following software components are used in this project:
- The Things Network - To connect our gateway data to various integrations. Please note that if we use the Helium Network, we just have to substitute this with the Helium Console.
- ThingspeakIoT - This is the integration we use to view our sensor data on an online dashboard and also perform analytics on this data using Matlab analytics provided by Thingspeak.
- ArduinoIDE to program our LoRa Node with is made using an Arduino UNO with a LoRa Shield.
- Raspbian - The OS we use on our Pi.
7Schematic Diagram of the Gateway and Node and Working
Before diving into the implementation of the whole project, I would like to give a brief note on how will this system work and what are the main components that will be a part of this system. For that, first have a look at the Schematic Diagram of the system.
Note : When we use the Helium Network, we substitute the Arduino Node with the STM node which is the Helium Developer Kit.
From the above schematic diagrams, we can get a clear understanding of how the whole system will work. So, here is a step by step explanation on what will happen in the system:
1. Node Data Acquisition: First, each node is battery powered. They have 3 air quality sensors attached to the Arduino I/O ports, two to digital pins and one to an analog pin. Each sensor will be sending the measured data to the Arduino every 10-20 seconds.
2. Sensor Data Transmission: Once the data has been received by the Arduino microcontroller, it is then pre-processed (converted in bytes format so it can be easily transmitted). Now, this processed data is sent via the LoRa shield at a specific frequency of 868.3MHz.
3. Data Reception: Now that the data has been transmitted, it will be received by the gateway with a specific amount of time, depending on the distance between the Node and the Gateway. This received data can be viewed on the Things Network Page for that particular node. Please note that there are some additional settings which need to be applied to get the data in proper format. These settings will be discussed later in this chapter.
4. Thingspeak Dashboard Update: After receiving the data, we have setup our things network such that it will funnel all its received data to Thingspeak IoT dashboard. There we can view any of the changes in the sensor data in real time and even create graphical user interfaces for better understanding.
8Sensor Interfacing
We will see how to interface the 3 given sensors to an Arduino UNO or Arduino compatible board. So, let us start with the first sensor that is the CCS811 Sensor.
1.1 CCS-811 Gas Sensor Arduino Interfacing
The CCS811 is an I2C sensor hence the interfacing part will be similar to any other I2C sensor that we have.
You can easily wire this breakout to any microcontroller; we'll be using an Adafruit Metro (Arduino compatible) with the Arduino IDE. But you can use any other kind of microcontroller as well as long as it has I2C clock and I2C data lines. Note this chip uses clock stretching so make sure your microcontroller supports that in hardware!
Wiring:
Now, for microcontrollers with dedicated SCL and SDA pins, please use them instead of using the A4 and A5 pins like me. Moreover, there are 2 addresses in general used for this sensor, which are:
- 0x5A
- 0x5B
In my case, even though the default address is 0x5A, my sensor had the address 0x5B which can be easily checked using the i2cdetect Arduino code. I have added all the codes in a later section titled “Codes” as there are many codes involved in this project. Please remember to connect the Wake pin of the sensor to ground pin of Arduino. The interfacing diagram is shown below.
Next, Download Adafruit_CCS811 library
To begin reading sensor data, you will need to download Adafruit_CCS811 from the Arduino library manager.
Open up the Arduino library manager and search for this library and download it.
Next, Open up File->Examples->Adafruit_CCS811->CCS811_test and upload to your Arduino wired up to the sensor. This example connects to the sensor and starts taking readings.
Once uploaded to your Arduino, open up the serial console at 9600 baud speed to see the readings. Your sensor will take 3 zero readings while it does some internal calibration and correction things and then start outputting real data. In clean air and a typical indoor space your serial monitor will look something like this:
5.2 Mics5524 Gas Sensor Arduino Interfacing
The MiCS-5524 is a robust MEMS sensor for indoor carbon monoxide and natural gas leakage detection; suitable also for indoor air quality monitoring; breath checker and early fire detection.
Detectable gases
• Carbon monoxide CO 1 – 1000ppm• Ethanol C2H5OH 10 – 500ppm• Hydrogen H2 1 – 1000ppm• Ammonia NH3 1 – 500ppm• Methane CH4 >1000ppm
One thing to note is that this sensor is sensitive to multiple gases, as you can see above – but does not know which gas it is.
So, here is the interfacing schematic.
5.3GP2Y1014AU0FInterfacing with Arduino
Below shown is the wire numbering of the sensor and its interfacing diagram with the Arduino Uno.
Please note that all the demo codes for this sensors are included in the Github repo. -
9Lora Components Setup
This chapter covers the following topics in this order:
1. Gateway Setup
2. TTN Account Setup
3. Node Setup
After this setup, you would be able to send the “Hello World!” String via Lora from your Node to your TTN Gateway and Device on an interval of 30 seconds to 1 minute.
So, let us get started:
6.1 Gateway Setup
This document has been written for the gateway version LG-01 N manufactured by Dragino. So, follow the below steps to get your gateway up and running for LoraWAN applications.
- · Unbox the gateway, connect the given antenna in the ANT-1 port and power it using the given power supply in the box.
- · Now, after it starts up, wait for a few seconds and then you will see that there will be 2 yellow lights glowing as shown in the figure below.
- · Now, there are 2 options to connect the gateway to your PC:
(Note – If you have done this process before for different gateways (with different firmware files), just do this setup in an incognito or private Window to prevent cached addresses, so you do not get the error as shown below)·
i) When you see the Wi-Fi symbol light blinking on the board, this means that it has setup a local Wi-Fi network. The name of the network will be ‘dragino-xxxxx’. Just connect to this network and then open ’10.130.1.1’ on your favourite browser.
ii) (Recommended) For this method, you will need an Ethernet cable. So, first connect the LAN Port of the gateway to the LAN port of your PC. Now, follow the same procedure as above and open the default gateway IP ’10.130.1.1’ on your favourite browser (not Internet Explorer)
After this process, you will see that your device is up and you will see it as follows:
- · After the 3rd step, your will see the following window on your browser:
Now, just go on and sign in with the default credentials, which are as follows:
Username: root
Password: dragino
If everything is good, you will successfully login to your gateway page, from where we can set it up to work as a number of things. For example, A MQTT Server, A Mesh Node of a bigger Lora Network, A Lora Gateway (we are interested in this), etc.
- · Now, this will take you to the home screen of your gateway. Congratulations, your PC is successfully connected to your PC! The home screen will look something like this:
Please note that you will need the firmware version LG02_LG08-5.2.15xxxxxxxx for this project. If you have any other firmware, just go to System >> Backup/Flash Firmware and reflash the desired firmware. You can download the firmware from this link.
Now, the next step is to connect the gateway to Internet.
· For connecting to the internet (specifically Wi-Fi), just go to the following from the menu:
Network >> Wireless
After that, just follow the given steps:
· First, disable the block with SSID name “dragino-xxxx” so that we can use that to connect to our own Wi-Fi Network
· Now, on top you will find a block saying Generic MAC80211 802.11bgn. In that, just press the Scan button and you will be redirected to the following page:
· Now, connect to your Wi-fi network and enter your Password in the field “WPA Passphrase”. After that, press the Submit button.
· Now, you will be taken to the next page wherein you have to change nothing, go to the bottom of the page and press on Save and Apply button.
· After pressing it, you will see that on the screen it will show something like “Applying Configuration, wait for xx seconds”. After some seconds, the new config will be applied.
· To confirm that you are connected to the internet, check the Wi-fi Symbol light on the gateway is blinking and just go to Network >> Diagnostics and ping any random URL. If you get a response, it means you are connected. Or else, you will see something like this:
“$$URL$$ Bad Address……”
If you get this, just repeat the process again and make sure you enter the right address and all.
- · Now that Wi-fi is connected, we can go on and setup the LoRaWAN Gateway part. For that, go to “Service >> LoraWAN Gateway”. You will be taken to a new page.
Now, just refer the above figure and fill all the details as given. Just change the gateway address with the address that you have given in your TTN Gateway Page. (TTN part will be covered in the next step, so you can just enter any arbitrary value for now (TTN Part – step 7))
After everything is entered, just press Save and Apply and let the new configurations be added. After this process, your Gateway is Ready!
Now, we will move to the next step of this setup, the TTN (the Things Network) Account setup.
10TTN Account Setup for Lora Air Quality Project
1. Signup TTN network by visiting the URL https://www.thethingsnetwork.org/
2. Give your details and create a new account.
3. Login with your credentials using the sign in page.
4. After you have Logged in, go to console page using the menu shown in the figure below.
5. In that console page you can see Tab to create your page for Application and Gateway.
Gateway Registration
6. First, Register GATEWAY using GATEWAY tab
Click GATEWAYS Tab a register gateway
7. Then Give Details as follows
a. Gateway ID: <as per the format in below image — it should be unique>
b. Tick I’m using the legacy packet forwarder
c. Description: <anything for your reference>
d. Frequency Plan: <Europe 868MHz>
e. Router: <ttn-router-eu>
f. Antenna Placement: <Indoor / Outdoor>
Once you have given Gateway ID in the format given then it converts it into Gateway EUI. If it shows any warning or error click on that message then it will go. Then click Register Gateway
Here My gateway ID is 12 34 56 7A BC DE FF FF
8. Check your Gateway Registration here ensure the highlighted fields
Application Registration
9. Click Application tab and add application
10. Give Details and Add Application
Note: Application ID can only exist of lowercase alphanumeric characters, non-consecutive — and it cannot start or end with a — or a. _
11. Check the highlighted parameters
12. This step is not Mandatory <Suggested to use default EUI> To change the Application EUI go to settings tab and add EUI your new EUI and Remove the old EUI
13. After step 11, Click on 0 Registered Device
14. You will get the following screen in that click register device
15. In this Register device page, you have to give following details and give Register
a. Device ID: <Give Unique ID for your reference.>
b. Device EUI: <Give 8 bytes Hexadecimal unique ID.>
16. On successful registration, Check the Device Overview in the following location as per the image
17. Change Activation method from OTAA to ABP
To change the modes from OTAA to ABP go to Settings and click on ABP and save the changes by keeping remaining things default.
For More details on OTAA and ABP visit the following Link https://static1.squarespace.com/static/560cc2c2e4b01e842d9fac18/t/5a938d38ec212d945 1fbecf8/1519619387035/OTAA_or_ABPv3.pdf
18. Check the Device overview in the following location as in the image
19. Click on “< > “options in Network Session key and APP Session Key to see the Hexadecimal values of key.
Also, you can copy the key by clicking option highlighted in blue color to paste it in program. Device address, Network session key and App session key all should be in the format as displayed in the image to use it in the program.
Now, the TTN account all setup. All that remains is the Node setup.
