LogiSim
Basically I am using SubLEq to teach myself LogiSim.
Is it even possible to get anything useful out of a 4 bit SubLEq.
Actually, yes I can get a 4 bit counter working in LogiSim.
74XXX Libraries
You will need some external 74XXX libraries. I used 74xx Libary.circ (https://github.com/kara-abdelaziz/CHUMP-processor/) and logi7400ic.circ (https://github.com/r0the/logi7400). Did not find a library that was complete.
I found and error in logi7400ic.circ for the 74161. The clock input was inverted. I modified my version of the library to fix it. Taking down this error took many hours.
From Concept to Working Simulation
I am impressed, about 15 hours over three days as a LogiSim novice.
Structure
LogiSim encourages the user to design your circuits hierarchically. Both with "bit width" and sub-circuits. As SubLEq is difficult to understand this is a good approach.
Programming SubLEq
Here is the binary counting program I am trying to implement:
Address | A | B | C |
0 | 0 | 1 | 3 | Z = 0 |
P = 1 |
3 | 1 | 0 | 6 | Z = -1 |
6 | 0 | F | 9 | B = B + 1 |
9 | 0 | 0 | 3 | Z = 0 |
C | 0 | 0 | 0 |
F | 0 |
I/O |
Usually address -1 or in the case 0xF serves as Input/Output or output in this case.
Note: A write to the I/O address also write the value to memory.
SubLEq has only one instruction:
- Mem[B] = Mem[B] - Mem[A] and jump to C if the result is Less or Equal to zero.
Decoding the Binary Counter Program
Address Comment
0 0,1,3 ;Set up Z (=0) and P (=1)
Usually this is written:
0 0 1 ? ( ? means the very next address)
3 1 0 ? ( 1 is the count increment, set Z = -1 )
6 0 F ? ( Increment the output address 0xF )
9 0 0 3 ( Reset Z = 0 and jump to address 3 )
C 0 0 0 ( Not reachable but: Reset Z = 0 and jump to address 0 )
F 0 ( The I/O address )
I am sure you all got the above and can now program in SubLEq.
Where to Start?
The timing diagram. I can do this because I have a bit of an idea what the sub-system look like:
![](https://cdn.hackaday.io/images/4085371631106975790.png)
Lets put this into steps:
Timing | Micro Code | Clock |
T0 | MAR=M[PC] |
T1 | ALU_A=M[MAR] | PC++ |
T2 | MAR=M[PC] |
T3 | ALU_B=M[MAR] |
T4 | M[MAR]=ALU_OUT; !WE; | PC++ |
T5 | IF (LEQ) THEN PC=M[PC] ELSE PC++ |
Don't be misled, although I present a linear process, it is still iterative.
The ALU
The ALU is fairly simple:
Subtract: B = B - A
Flag: !LEq
Therefore we need:
- Load A: !ALU_LDA
- Load B: !ALU_LDB
- Read B - A: !ALU_OUT
And because of the type of control logic I am using:
- Clock: CLK
- Reset: RST
Here is my schematic:
![](https://cdn.hackaday.io/images/2938481631090986931.png)
Chip Count:
- 2x 74HC173
- 2x 74HC283
- 1x 74HC04
- 1x 74HC125 (the inverter and tri-state output buffers)
The beauty of LogiSim is that you can test the sub-circuit before proceeding.
Program Counter
The program counter is perhaps the simplest sub-circuit to design. Note: the outputs PC0-3, these are for debuging LED display in the top level:
![](https://cdn.hackaday.io/images/3167651631103916349.png)
Note: the 74161 in the logi7400ic.circ library has the clock inverted. I have edited my version of the library.
Memory Address Register (MAR)
The idea behind the MAR is to load a value from memory and then use that value as an address to load an indirect memory value. Thus it is a form a indirect addressing.
![](https://cdn.hackaday.io/images/7539411631106402503.png)
Note: the MAR0-3 outputs are for debugging.
Output
Output for SubLEq is a little tricky, I have solved this by shadowing a memory location (-1 or 0xF) for the output register. So reading the output just returns the value stored in memory during the write to the port.
![](https://cdn.hackaday.io/images/1806191631106498620.png)
Input
Don't need an input for this demonstration computer but if required it would be mapped to -2 or 0xE. The memory location would be need to be disabled.
The Control Logic
Now that the main sub-circuits have been designed and there control signal named we can map the timing diagram to logic:
![](https://cdn.hackaday.io/images/7565141631107001437.png)
The core of the control logic is a Johnson counter (2x74HC175) setup to cycle a six state low bit (for T0):
- T0 T1 T2 T3 T4 T5
- 0 1 1 1 1 1
Reading the timing table !PC_EN (enable the PC count), a 3 input AND gate on T1, T4 and T5 will meet the control specification:
![](https://cdn.hackaday.io/images/3787031631107327418.png)
With all the control systems I have played with this is absolutely the simplest (I have come across).
The Top Level Circuit
Here is the top level circuit:
![](https://cdn.hackaday.io/images/1169241631107489734.png)
As you can see I don't bother connecting the sub-circuits up to each other via wires. Just use the "tunnels". If you didn't know, if you hover the mouse over the sub-circuit pin it tells you the pin name.
The Simulation
And here is the simulation:
https://cdn.hackaday.io/files/1816007769574400/4Bit_SubLEq-2021-09-08.mkv
AlanX
