1Circuit Connection
- FIrst make the circuit as per the schematics. This circuit is the basic interface of LCD display with Arduino Uno
2Install Libary
Go To Arduino IDE install "Liquid Crystal Libary
3Step 3
- Now open examples -> LiquidCrystal -> SerialDisplay
- Select Port Number and Board Type upload the code
4Python File
- After Uploading Open the python File
- Before Executing Install the packages and Enter the Arduino Port No
- Make Sure "INTERNET IS TURNED ON"
- Now run the python file
- Now you can see output in the LCD display
5Output
prabeenraj01
