CAN extruder first printing.
printing test:
motor sync test:
Reduce the wires from more than 19 to only 4
printing test:
motor sync test:
Schematic_extruder_2021-10-19.pdfAdobe Portable Document Format - 130.10 kB - 10/19/2021 at 02:31 |
New version of CAN Extruder Board is now orderable, beside support normal thermistor temperature sensor, it has one more chip MAX31865 that can support PT100 temperature sensor(-30°C to 500°C)
Another version of CAN bus extruder, support PT100 for High temperature.
with wifi the biggest challenge is the E motor needs to sync data with all the X/Y axis. but it's no problem with bowden extruder printer that's no E motor on the Hotend,because you no need to sync temperature data in realtime.
I'm a bit surprised to see an ESP in there, are you planning to replace the CAN bus with WiFi? :D
But its a nice idea to reduce the number of wires. Had quite some trouble with broken wiring on prusa printers.
