Unzip the folder and then run the app. After trying to open it, you will need to open Settings - Security and Privacy - click on Open Anyway where it says BetterSerialPlotter was blocked.
Unzip the folder and then run the app. You need to run the app with sudo permission because it requires access to the serial port. Note that if you don't run it with sudo, it will still run, but serial ports won't open.
