19 Sept 2021
09/19/2021 at 06:37 • 0 commentsContinuing on in my quest for control over this device I decided to test whether other methods of controlling the drone will lead to some output on the device itself.
Theory 1 :
Packets sent not frequently enough.
As seen above there a large number of the larger packets being sent as opposed to the smaller packet example (when in reference to the 2 packets mentioned in 18 Sept 2021 Log).
Theory 2:
In my last recording I had picked up a new request which has not come up earlier when trying to scan over a network on my pc while my android device controls the drone.
After Googling about this protocol I found that this was to do with giving IP addresses as devices joined then I digressed back into testing Theory 1.
To test this I configured the code slightly so that It will not just pause in the while true loop.
s2.send(bytes.fromhex('7F')) while True: data, addr = s1.recvfrom(1500) sys.stdout.write(str(data)) s2.send(bytes.fromhex('19 FF FF FF FF 7F 7F E6')) print("\r\n sent") #data = s2.recv(106) print(data)
After testing this on the device on both ports given by the RSTP request
I then tested sending both codes in sequence in the while loop.
s2.send(bytes.fromhex('7F')) s2.send(bytes.fromhex('19 FF FF FF FF 7F 7F E6'))
This did not yield results either thus began the test with the most accurate representation to what we see in the live environment.
This allows for 11 of the more frequent messages to be sent before the smaller one.
Alas this did not bring about any visible change on the device.
n = 0 while True: data, addr = s1.recvfrom(1500) sys.stdout.write(str(data)) s2.send(bytes.fromhex('19 FF FF FF FF 7F 7F E6')) if n == 10: s2.send(bytes.fromhex('7F')) print("\r\n sent") #data = s2.recv(106) print(data) n = n+1
After pondering for some time as to what the difference was between the code that works and my code.
I then realized that perhaps the port I am communicating using is not recognized because it differs from the one receiving video.
I then decided to only loop the program once and printout the address and then configured the following code to send from the next port up from the one currently bound to receive packets.
s1 = socket.socket(socket.AF_INET,socket.SOCK_DGRAM) s1.bind(("",57795)) s2 = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) s2.bind(("", 57796))
[loop code change]
n=0 while True: data, addr = s1.recvfrom(1500) data2, addr2 = s2.recvfrom(1500) s2.sendto(bytes.fromhex('19 FF FF FF FF 7F 7F E6'),0,addr2) print("\r\n S1 Address = " + str(addr)) print("\r\n S2 Address = " + str(addr2)) if n == 10: s2.sendto(bytes.fromhex('7F'),0,addr2) n = 0 print("\r\n s2 packet sent") #data = s2.recv(106) print(data) print(data2) n = n+1
Which this appears to be allowing myself to receive packets and also had an interesting effect on the lights on the drone, as it seems to engage them in the same way when you pressed the on button(in the android app) before which the LEDs seem to flash consistently.
I also receive this in the output console on my code.
b'OPTIONS rtsp://192.168.1.1:7070/webcam RTSP/1.0\r\nCSeq: 1\r\nUser-Agent: Lavf56.40.101\r\n\r\n' package sent package recved b'RTSP/1.0 200 OK\r\nCSeq: 1\r\nPublic: DESCRIBE, SETUP, TEARDOWN, PLAY, PAUSE\r\n\r\n' b'DESCRIBE rtsp://192.168.1.1:7070/webcam RTSP/1.0\r\nAccept: application/sdp\r\nCSeq: 2\r\nUser-Agent: Lavf56.40.101\r\n\r\n' package sent package recved b'RTSP/1.0 200 OK\r\nCSeq: 2\r\nContent-Base: rtsp://192.168.1.1:7070/webcam/\r\nContent-Type: application/sdp\r\nCo' b'SETUP rtsp://192.168.1.1:7070/webcam/track0 RTSP/1.0\r\nTransport: RTP/AVP/UDP;unicast;client_port=57795\r\nCSeq: 3\r\nUser-Agent: Lavf56.40.101\r\n\r\n' package sent package recved b'ntent-Length: 122\r\n\r\nv=0\r\no=- 1 1 IN IP4 127.0.0.1\r\ns=Test\r\na=type:broadcast\r\nt=0 0\r\nc=IN IP4 0.0.0.0\r\nm=v' b'ideo 0 RTP/AVP 26\r\na=control:track0\r\nRTSP/1.0 200 OK\r\nCSeq: 3\r\nTransport: RTP/AVP;unicast;client_port=57795-57796;server_port=56262-56263\r\nSession: B4B5B6B7B8B9BABBBCBDBEBFC0C1C2\r\n\r\n' Session: B4B5B6B7B8B9BABBBCBDBEBFC0C1C2 ['server_port', '56262-56263'] b'PLAY rtsp://192.168.1.1:7070/webcam RTSP/1.0\r\nRange: npt=0.000-\r\nCSeq: 4\r\nUser-Agent: Lavf56.40.101\r\nSession: B4B5B6B7B8B9BABBBCBDBEBFC0C1C2\r\n\r\n' b'RTSP/1.0 200 OK\r\nCSeq: 4\r\nSession: B4B5B6B7B8B9BABBBCBDBEBFC0C1C2\r\n\r\n' S1 Address = ('192.168.1.1', 56262) S2 Address = ('192.168.1.1', 56263) s2 packet sent b'\x80\x1a\xb3\xb2\xb1\xc6\xbaB\xad\xac\xab\xaa\x00\x00\x00\x00A\xffP<\x04\xa4\x80\xc0\x00\x00\x00\x80\x17\x10\x11\x14\x11\x0e\x17\x14\x12\x14\x1a\x18\x17\x1b"9%"\x1f\x1f"F25)9RHWUQHPN[f\x83o[a|bNPr\x9bs|\x87\x8b\x92\x94\x92Xm\xa0\xac\x9f\x8e\xaa\x83\x8f\x92\x8d\x18\x1a\x1a"\x1e"C%%C\x8d^P^\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\xe5i)h\xa0\x05\x14\xb4\xda\\\xd0\x02\xd1I\x9aZ\x00\x05H\xa7\x8a\x8a\xa4C@\n\xfd*:\x91\xaa3@\x01\xe9M\xa7u\x14\xd3@\x05\x14Q@\x05(\x14\x94\xb4\x00\xb4\xe1M\x14\xe1@\x0bM\xa5\xa4\xa0\x04\xa0\xd0h\xa0\x06\x9a)i(\x01E:\x9a)h\x01iE%\x14\x00\xeaCFi(\x00\xa2\x8a(\x01\r%8\xd3h\x00\xa5\xa4\xa2\x80$SN\xa6-:\x80\n(\xa3\xa5\x00-\x14\xdf3\'\n\x0b\x1faR\xa5\xb5\xd3\x8c\xad\xac\xa7\xf04\x01\x1d-L\x96\x17\xd2\x1c-\xa3\x83\xef\xc5Y]\x07R~\xab\x1a\x0fv\xa4\x06}\x15\xa6\xde\x1c\xd4\x00\xca<.}\x03U9\xb4\xfb\xf8?\xd6\xdaH=\xc0\xcf\xf2\xa0\n\xf4R3mm\xae\xac\xa7\xd0\x8a\x01\x07\xa1\xa6\x01E-%\x00\x18\xa4\xa5\xa2\x80\x01E\x14P\x01E\x14P\x02\x8a))h\x00\xa2\x8a(\x00\xa2\x8a(\x00\xa0\xd1A\xa0\x06\xf7\xa7\x8agzx\xa0\x07\n\xde\xd1\xbf\xe4\x11\x08\xff\x00i\x8f\xebX\x1d\x8do\xe8\xfcip\x7f\xc0\x8f\xfe<h\x03@S\xc5G\xc9\x1cu\xa9V\x90\xc7)\xa5\xa4\xa3\xa5M\xc0Z\x05\x14\x94\xc0Z)(\xa0\x07QI\x9fZCHc\xb3\xef\xc5\x14\xdc\xd2\x8a\x04\x7f\xff\xd0\xe5i)h\xa0\x02\x8a(\xa0\x02\x8a(\xa0\x05\xa7)\xa6S\x94\xf3@\x12\x1e\x94\xc6\xa7\x8eE5\x86\r\x004R\x1aZC@\tE\x14P\x01E\x14P\x02\x8ap\xa6R\x83@\x0f\xa6\x9a\t\xa6\xe6\x80\x174RQ@\x05\x14\xb4\x94\x00\np\xe9M\xa34\x00\xeaL\xd1E\x00\x14\xb9\xa6\xd2\xd0\x03\x85\x06\x9a\r:\x80\x12\x92\x9dM4\x00P(\xa2\x80\x1e\xbdiK\x00q\xd4\xfa\nH\xc6\xf9Q\x0f\x01\x8e+\xaa\xb0\xb1\xb7\x82%e\x89w\x91\xf7\x8f&\x800\xedt\xab\xdb\xa2\x0e\xcf)?\xbc\xd5\xa9o\xe1\xfbX\x883\xb3L\xdf\x90\xadjk\xc8#R\xccx\xa4\x03b\x86\x18\x17l0\xc6\x83\xd9EI\x93\xebQ\xc5:Hp\x08\xcdK\xc7z\x00\\\x9cu4\xa0\xf1\xc5\'\xb0\xa4c\x8a\x00Eo\x9f\x15&\xf2\xbft\x9f\xce\xa0\x07\xe6\xcfz~@\xeb@\r\x98\xac\xb9\x12D\x8f\xf5Pk>}\x1a\xc6s\xccf&\xff\x00`\xe0~U{\xcd\n\xa7#\x9a\x84\xcaG\n3\xeeM\x00c\xcd\xe1\xf9T\x9f\xb3\xdc+\x0e\xc1\xc6*\xbf\xf65\xfepQ\x07\xb9j\xde\xf3\t\xeb\xd6\x8c\xe7\xbd\x00b\xae\x85rT\x17\x9e5>\x9dh}\x0e\xe0\x03\xb2x\xdc\xfat\xad\x9ai4\\\x0ej{[\x9bc\xfb\xe8X\x01\xfcC\xa5D\x08=+\xabV\xc7\x07\x91\xe8j\xa5\xe6\x93\r\xd0/\t\x11K\xed\xd0\xd3\x1d\x8c\n)\xf3\xc3%\xb4\xa6)\xd7k\x0f\xc8\xd3(\x10R\xd2Q@\x05-\x14P\x01E\x14P\x01Hii\r\x00 \xebO\x15\x1fz\x90P\x02\xf6?J\xe84\x91\x8d.\xdf\xdc\x1f\xfd\x08\xd7<\xdfq\xbe\x86\xbaM4m\xd3-\x81\xfe\xe6\x7fSH\x0bkR\x0e\x95\x1a\xd3\xc5&1\xc34\xb4\xdc\xd3\x87J\x00_\xa1\xa4\xa4\x1dih\xb8X\\\xd1M\xa3\x9a@8Pi\x05\'9\xa1\x00\xa0\xd1\x9a(\x04P\x07\xff\xd1\xe5h\xa2\x8a\x00(\xa2\x83@\x05\x14\x94\xa2\x80\nP))h\x02D\xa5qLSO\'\x8a\x00\x8f\x14Ph\xcd\x006\x8a\r\x14\x00QE\x14\x00\x94\xa2\x8a(\x004QE\x00-\x14\x94\xb4\x00Q\x8aJ(\x00\xa2\x8a(\x00\xa5\xa4\xa5\x14\x00\xb8\xa4\xa5\xa2\x80\x12\x96\x92\x8a\x00u!\xa2\x8a\x00JZJ(\x01rQ\x95\xc7\xf0\x9c\xd7ci kTn\xd5\xc6\x9f\xbak\xa5\xd2nW\xfb=C\x1f\xbb@\x1a&\xe2\x10\t2\x0c\x8e\xd5\x9f<\xde{\xe4\xe4 \xfb\xa3\xfa\xd4r\xcf\xe6\xb9pp\t\xa1X6E \x1f\x19\x01\xb3\xfc\xaa\xec\x13\xaf\n\x7f\n\xce\x07i\xcfQJ\n\x8c\xe3<\xfa\xd0\x06\xda\x90zS&8\x00\xd6tWRG\xd8\x91S4\xc6NI\xa2\xe1bR\xe0S\x19\xf7w\xa8\xf3Fh\x01I\xcd7\xa0\xc5:\x93\x19\xa0\x06\xd2\x95\xc8\xe7\x9a:R\xd2\x18\x9d\x05\x1dh\xa3\x8a`\x14\xe54\xca;\xd0\x04\x93E\r\xd4F+\x85\xc8\xec{\x8a\xe7/ld\xb1\x97k|\xd1\xb7\xdcz\xe87TZ\x82$\xdaL\xc1\xc7\xfa\xa5\xdc\x0f\xbd\x029\xba(\x1ft}(\xa6\x01KE%\x00.(\xa34P\x01Hii\r\x00\'zx\xe9L\x14\xf1@\x03}\xc6\xfaWKc\xc6\x9fk\xff\x00\\\xc5sNp\x87\xe9]5\x9f\xfcx\xdb\x0f\xfad\xbf\xca\x90\x16E<Tb\x9e)0\x17\x14\xb4\x80\xf1Fi\\c\xa9(\xa2\x90\xc5\xa4\xe74QB\x10\xb4\x13I\x9a(\x01z\x8aJUlg\xbd&@\xe9@X\xff\xd2\xe5)i(\xa0\x05\xa3\x9a\x05-\x00&(\xc5-\x14\x00QKE\x00\x14d\xd2Q@\x05!\xa2\x8a\x00(\xa4\xa5\xa0\x02\x8aJ(\x01h\xa2\x8a\x00))i(\x01h\xa2\x92\x80\x16\x92\x96\x8a\x00))h\xa0\x00S\xa9\xb4\xb4\x00\xb4\x94Q@\x0bE%\x14\x00\xb4\x94Q@\x05\x14Q@\x0bWt\xf6\xceP\xf4\xcdR\x19\xa9 \x7f.L\xf64\x01\xb1\xd0\xe0' b'\x80\xc8\x00\x06\xad\xac\xab\xaa\x83\xaa\x7fr\xc9\xba^5\xb1\xc6\xbaB\x00\x00\x00\x01\x00\x00\x05\xac\x81\xca\x00\x04\xad\xac\xab\xaa\x01\x0eUnnamed stream'
This now leaves me with yet another packet I am unable to decode, This second packet appears to be not as long as the first however with the same first byte as the original packet.
Perhaps this is the telemetry from the drone itself to allow calculations to be based on the current position of the drone.
However that is where I will leave things today while I try to construct a method of determining all inputs allowed into the s2 socket.
18th Sept 2021
09/18/2021 at 08:13 • 0 commentsHello to of you reading this.
Apologies in advance for a lack of in-code documentation.
However lets get on with the show.
___________________________________________________________________
To start being able to communicate with this device I determined that I would first need to identify what packets are being consumed by the device itself (JXD 523 Drone).
This proceeded the opening of Microsoft Network Monitor to obtain the contents shown in yes.cap in the download area and then focusing on the communication between 192.168.1.1(server\drone) and 192.168.1.101(Android\interfacing device).
As we can see we have an initial SIP request which also refers to an URL which may be the key to communicating with our device.
Using the details in this packet I then was able to construct these packets in python and began trying to interface with the device.(Format of code was assisted by looking at a similar project by https://hackaday.io/AJF1982.
import socket import time import sys s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) s.connect(('192.168.1.1', 7070)) package= b'OPTIONS rtsp://192.168.1.1:7070/webcam RTSP/1.0\r\nCSeq: 1\r\nUser-Agent: Lavf56.40.101\r\n\r\n' print(package) s.send(package) print("package sent") data = s.recv(106) print("package recved") print(data)
Once I ran this code I had received a response of the following.
With some more work I was able to then use the sequences above just by replacing the first keyword at the start of every line after the identifier of b' and incremented the CSeq: number which worked well until I got to the play line which returned Session not found until I added an extra s.recv command and made the package line more modular on line 39. (please see RSTPcontrol.py)
With my code set to complete the entire output looks like this:
b'OPTIONS rtsp://192.168.1.1:7070/webcam RTSP/1.0\r\nCSeq: 1\r\nUser-Agent: Lavf56.40.101\r\n\r\n' package sent package recved b'RTSP/1.0 200 OK\r\nCSeq: 1\r\nPublic: DESCRIBE, SETUP, TEARDOWN, PLAY, PAUSE\r\n\r\n' b'DESCRIBE rtsp://192.168.1.1:7070/webcam RTSP/1.0\r\nAccept: application/sdp\r\nCSeq: 2\r\nUser-Agent: Lavf56.40.101\r\n\r\n' package sent package recved b'RTSP/1.0 200 OK\r\nCSeq: 2\r\nContent-Base: rtsp://192.168.1.1:7070/webcam/\r\nContent-Type: application/sdp\r\nCo' b'SETUP rtsp://192.168.1.1:7070/webcam/track0 RTSP/1.0\r\nTransport: RTP/AVP/UDP;unicast;client_port=57795\r\nCSeq: 3\r\nUser-Agent: Lavf56.40.101\r\n\r\n' package sent package recved b'ntent-Length: 122\r\n\r\nv=0\r\no=- 1 1 IN IP4 127.0.0.1\r\ns=Test\r\na=type:broadcast\r\nt=0 0\r\nc=IN IP4 0.0.0.0\r\nm=v' b'ideo 0 RTP/AVP 26\r\na=control:track0\r\nRTSP/1.0 200 OK\r\nCSeq: 3\r\nTransport: RTP/AVP;unicast;client_port=57795-57796;server_port=55934-55935\r\nSession: 82838485868788898A8B8C8D8E8F90\r\n\r\n' Session: 82838485868788898A8B8C8D8E8F90 ['server_port', '55934-55935'] b'PLAY rtsp://192.168.1.1:7070/webcam RTSP/1.0\r\nRange: npt=0.000-\r\nCSeq: 4\r\nUser-Agent: Lavf56.40.101\r\nSession: 82838485868788898A8B8C8D8E8F90\r\n\r\n' b'RTSP/1.0 200 OK\r\nCSeq: 4\r\nSession: 82838485868788898A8B8C8D8E8F90\r\n\r\n' b'\x80\x1a\x81\x80\x7f~\xa0\xa4{zyx\x00\x00\x00\x00A\xffP<\x04\xb9\x81\x00\x00\x00\x00\x80\x17\x10\x11\x14\x11\x0e\x17\x14\x12\x14\x1a\x18\x17\x1b"9%"\x1f\x1f"F25)9RHWUQHPN[f\x83o[a|bNPr\x9bs|\x87\x8b\x92\x94\x92Xm\xa0\xac\x9f\x8e\xaa\x83\x8f\x92\x8d\x18\x1a\x1a"\x1e"C%%C\x8d^P^\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\x8d\xbe\xd0\xf3\xd2\x98b\xc7\xadj\x18j6\x84\xfaWj\xa8I\x9ab4\xd3\x11\x15\xa0`>\x95\x19\x83\xfd\x91V\xaa\x0c\xa0P\xfaSJ\x1a\xbeb\xff\x008\xa8\xcc>\xd5j`R*})\xa5O\xa5\\hi\x86\x1fJ\xb54\x05R(\xc5X1z\x81M1\x9fJ|\xc8\x08qF\rK\xb0\xd0P\xd3\xb8\x0c\x02\x8cS\xf6\xd1\x8aW\x02<R\xe2\x9f\x8a1E\xc7a\xa0R\xe2\x8cQ\x9a\x06\x19\xf5\xa6\x93A4\xd2i\xd8.)4\xd2i)*\xac+\x814\x94\xb8\xa3\x14\t\x858RQ@\x87\x03N\xcd34\xb9\xa4\x03\xb3J\rG\x9ap4\xac1\xf9\xa34\xda)X\x05\xa4\xa5\xa5\x02\x80\x10\n]\xbe\xd4\xe0\xb4\xf0\xb4\x9b\x19\x1e\xdar\xadH\x12\xa4X\xea\\\x861S\xda\xa5U4\xe5Oj\x95R\xb3r\x01\xaa\xb5"\xad9V\xa4\x0bY9\x00\xd5Z\x90-(\x14\xe0+6\xc5q\x02\xd1\x8aZ*n\x02b\x93\x14\xb4S\x00\xa2\x8a(\x00\x14\xb4QHAE\x14\xb4\x00R\xd0)i\x00QK\x8a\\R\x01\xb4\xb4\xb8\xa3\x14\x08)q@\x14\xb4\x80)h\xa2\x90\x05\x14Q@\xc2\x8a)i\x00RR\xd1@\x05\x14Q@\xc2\x8a(\xa0\x02\x8a(\xa0\x02\x8a(\xa0\x02\x8a(\xa0\x0f\xff\xd0\xea\xb6\x8aB\x99\xa7\xd1N\xe2\xb1\x11\x8f\xda\x98b\x1e\x95b\x93\x14\xd4\x98\x15LT\xc3\x00\xab\x98\x14\x85A\xabSb(4\x03\xd0~T\xc3\rh\x18\xc54\xc6*\xd5@3\x8c4\xc3\x0f\xa0\xad#\x18\xf4\xa6\x18\xbd\xaa\xd5A\x99\xa6/\xf3\x8a<\xafo\xd2\xaf\x98\xbd\xa9\x86\x1a\xa5Pe\x13\x154\xc7W\x8c5\x1bEV\xa6\x052\x94\xd2\xa7\xd2\xad\x98\xbd)\xa6#\x8e\xff\x00\x95R\x90\xca\xa5H\xedL`j\xd3&*6J\xa5 *\x9amX)\xedM\xd9Z&I\x15\x18\xa9vRl4\xee\x031I\x8a~)1E\xc46\x8a\\Q\x8a\x00m.h\xc5(Ri\x80\x80sO\x02\x95R\xa5\tR\xd8\xecE\x8apZ\x94%<E\xfeqP\xe4;\x10\x84\xa7\x88\xeaeOJxJ\x871\xa2\x15\x8f\xda\x9e#\xf6\xa9\x82{S\x82\xd49\x81\x12\xa5H\x16\x9e\x16\x9c\x16\xa1\xc8.4%H\xabJ\x05<\n\x86\xc4\x01i\xc0QFj\x00Z)3E!\x0bFi(\xa0\x05\xa4\xa2\x8a\x02\xe2\xd1E-\x00%\x14\xb8\xa5\xc5\x02lJ1N\xc5\x18\xa5p\xb8\x80S\x80\xa0\np\x14\x9b\x10\x01KF)jF&(\xc5-\x14\x00QE\x14\x00QE-!\x85\x14Q@\x05\x14Q@\xc2\x8a(\xa0\x02\x8a(\xa0\x02\x8a(\xa0\x02\x8a(\xa0\x02\x8a(\xa0\x02\x8a(\xa0\x0f\xff\xd1\xeb(\xa2\x8a\x00(\xa2\x8a\x00(\xa2\x8a\x00J1KE\x02\x1b\xb6\x90\xad>\x92\x9d\xc0\x8c\xa54\xa5Ji\xa6\xa91\x11\x14\xa8\xcaT\xe6\x9aj\x93`W()\x85*v\xc5FkD\xc6@\xc9\xedQ\xb4ud\xd3\x08\x15jB\xb9U\xa3\xa8\xccui\x850\x8a\xd1Hd\x1b=\xa96z\xd4\xd8\xa3\x15\\\xc1r\x0f/\xda\x9b\xe5\xd5\x82(\xdbO\x98\n\xc5)<\xb3V\x8a{Ryt\xf9\x86V\xd9\xedNX\xcf\xa5X\x11\x8apJ\x1c\xc0\x89c5"\xc7\x8e\xd5"\xa75(Z\xcd\xccdA)\xe2:\x93m8\n\xcd\xc8DA)\xe1i\xf8\xa5\xc5O0\\f(\x02\x9dE+\x80\x80S\x85%.h\x01\xc2\x96\x9a\r.jD;4f\x9bE\x00:\x8aJQHB\xd1E(\xa4 \xa5\xa0R\xd0\x02b\x97\x14\xa2\x9c\x05+\x80\xdcR\xe2\x9d\x8a1J\xe0&)qE- \x10\nu%\x14\x80Z(\xa2\x81\x85\x14Q@\x05\x14R\xd2\x18QE\x14\x0c(\xa2\x8a\x00(\xa2\x8a\x00(\xa2\x8a\x00(\xa2\x8a\x00(\xa2\x8a\x00(\xa2\x8a\x00(\xa2\x8a\x00(\xa2\x8a\x00\xff\xd2\xeb(\xa2\x8a\x00(\xa4\xcd\x19\xa0W\x16\x92\x90\x9aM\xd4\xec\x03\xa8\xcd3u!j,\x04\x99\xa4-Q\xee\xa6\x96\xa7`\x1eZ\x9aZ\x98Z\x98Z\xadDv\x1eZ\x98^\x98M4\x9a\xb5\x10\xb0\xac\xf4\xd2\xd4\xd2i\x84\xd5\xa4\x16\x1eZ\x9aZ\x98M&j\xac+\nM4\xd0M%U\x80(\xa3\x14\x01L,.)@\xa0\np\x14\x9b\x04\x84\xdbK\xb6\x9e\x05.*n1\x81i\xc1i\xd8\xa5\x02\x95\xc0EQN\xa0QR\x02\xd2\xd2QH\x05\xa2\x92\x96\x81\x05\x06\x8aJ\x00(\x14R\xd0+\x8a)E \xa7\x81I\x80\xdaZv)qJ\xe2\x1bJ)qF)\\\x00R\xd1\x8aZB\x01KE(\xa4\x02\x8ap\xa6\x8ap\xa9\x01h\xa2\x8aC\n(\xa2\x80\n(\xa2\x80\x16\x8a(\xa0aE\x14\xb4\x86\x14QE\x03\n(\xa2\x80\n(\xa2\x80\n(\xa2\x80\n(\xa2\x80\n(\xa2\x80\n(\xa2\x80\n(\xa2\x80\n(\xa2\x80\n(\xa2\x80?\xff\xd3\xea\xf3M-L-M\xddUa\x12\x16\xa4\xddQ\xee\xa35V\x0b\x0e-I\xba\x9aM&i\xd8v\x1f\x9a3L\xa5\xa2\xc1asM4\xb4b\x81\x8c4\xd2*LR\x11Uq\x91\xe2\x9aEJE0\xd5&"2)\x84T\xa4S\x08\xaaL\x08\x98S*R*2+D\x02QF)'
However attempts to play this using CV2 player have been unsuccessful as the data received is not recognizable.
I am sure that that given some more time I will be able to decode this data to be played.
When it comes to sending commands I will need to make the first chip which has the camera attached then communicate to the chip with the STM32 microcontroller onboard.
My current theory is that these controls get sent to the server port (Found in the reply after the setup command) via UDP to the same IP address as seen on the following stream:
As when we open this to see all frames the source IP Address appears to be the android device being used to control the drone.
(as seen below)
Looking into these packets there is not much to read when we look at the payload as I am unsure on how to decode these messages or whether this is meant to be all hex.
All packets either have the above payload or the one below.
I then decided to connect to the port I received in the RSTP request using the following code.
s2 = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) s2.connect(('192.168.1.1', int(serverport[1])))
And then sent packets with the hex byte values replicated as below.
To which these looked identical to the packets I had captured in Microsoft Network Monitor. Alas no change in lights or action on the drone from these packets being sent.
Please feel free to reach out to me if you have any suggestions or anything at all to add to this project I will respond when I can.
