1Setup
First, connect the camera and LEDs to the RTL8722DM-MINI following the diagram below.
Download the Ameba customized version of TensorFlow Lite for Microcontrollers library at https://github.com/ambiot/ambd_arduino/tree/master/Arduino_zip_libraries.
Follow the instructions at https://www.arduino.cc/en/guide/libraries to install it.
Ensure that the patch files found at https://github.com/ambiot/ambd_arduino/tree/master/Ameba_misc/ are also installed.
You will also need to install the Ameba_ArduCAM library, found together with the TensorFlow Lite library.
In the Arduino IDE library manager, install the JPEGDecoder library. This example has been tested with version 1.8.0 of the JPEGDecoder library.
Once the library has installed, you will need to configure it to disable some optional components that are not compatible with the RTL8722DM. Open the following file:
Arduino/libraries/JPEGDecoder/src/User_Config.h
Make sure that both #define LOAD_SD_LIBRARY and #define LOAD_SDFAT_LIBRARY are commented out, as shown in this excerpt from the file:
//#define LOAD_SD_LIBRARY // Default SD Card library
//#define LOAD_SDFAT_LIBRARY // Use SdFat library instead, so SD Card SPI can be bit bashed -
2Programming
Open the example, “Files” -> “Examples” -> “TensorFlowLite_Ameba” -> “person_detection”.
3Final Result
Upload the code and press the reset button on Ameba once the upload has finished.
Once it is running, you should see the blue LED flashing once every few seconds, indicating that it has finished processing an image. The red LED will light up if it determines that there is no person in the previous image captured, and the green LED will light up if it determines that there is a person.
The inference results are also output to the Arduino serial monitor, which appear as follows:![]()
