Test #3: Ultrasonic sensor HC-SR04
05/01/2022 at 09:20 • 0 commentsUsing a HC-SR04 ultrasonic sensor to track the position of the cart.
Limiting the minima to 10cm and maxima to 45cm (~10mm clearance)
I used a cardboard cut-out to mount the sensor, and also as a rebound surface,
Although the least count is 1cm here, the reading seems to be pretty precise.
Test #2: Seeed magnetic encoder
04/12/2022 at 14:36 • 0 commentsTesting the magnetic encoder sensor from seeed with my Inverted pendulum system.
Magnet used: 5mm NdFeB cube Magnet
Used a basic code of I2C comm.
The sensor was very accurate and consistent.
Looking forward to integrate the Ultrasounic range sensor next.
Test #1: Stepper motor test
04/11/2022 at 15:31 • 0 commentsInverted pendulum system using a Nema17 stepper motor, driven by Microstep driver
Controlled by a Rotary encoder interfaced using arduino uno.
inferences:
- Better control achieved.
- Pulsed motion.
Further developments:
- Program modification for smoother motion
- Need to verify structure integrity.
Test #0: Motor and mechanism trial.
10/27/2021 at 16:48 • 0 commentsInverted pendulum system using 12V 775 DC motor, driven by L298N motor driver.
Controlled by a joystick interfaced using an arduino uno.observations:
- Irregular and abrupt motions.
- Motor unable to provide enough torque
- difficulty in precise controlling of the motorinferences:
- Driver limitations 2A output per channel. Hence, could not provide enough torque for smooth transmission.
- Mechanism is smooth without the motor involved. -
Final assembly
10/27/2021 at 16:13 • 0 commentsComplete assembly - belt, pulleys and electronics
3D printing
10/27/2021 at 16:10 • 0 commentsPETG - 3D printed parts:
- Pendulum rod holder
- Motor holder
- Idler pulley holder
- Sensor holder
Assembly
10/03/2021 at 14:22 • 0 comments -
CAD model
10/03/2021 at 11:38 • 0 commentsBlack parts are 3D printed parts. STL files to be uploaded soon.
Materials
09/24/2021 at 06:19 • 0 commentsAttaching images of items procured.
Meanwhile designing models that need to be 3D printed - motor mount, base plate, etc.
Soon to upload CAD models of the setup
