1Circuit Connection
The circuit connection is as shown in the figure below.
2Code
#include<AmebaServo.h> AmebaServo myservo; const int trigPin=3; const int echoPin=5; long duration; int distance; void setup() { Serial.begin(9600); myservo.attach(9); pinMode(trigPin, OUTPUT); pinMode(echoPin, INPUT); } void loop() { digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // measure time duration of pulse HIGH at echo pin duration=pulseIn(echoPin, HIGH); // calculate the distance from car to sensor distance=(0.034*duration)/2; if(distance<=10){ myservo.write(90); } else{ myservo.write(0); } Serial.print("distance: "); Serial.println(distance); Serial.print(" cm"); delay(1); }
