Hackaday.io Hackaday.io
Sign up Log in
3D Printer Timelapse SkyCam
Taking 3D print time lapses where the camera moves around the print.
pointlessly-usefulPointlessly Useful
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
222
1
6
5
Team (1)
  • pointlessly-usefulPointlessly Useful
Join this project's team
ongoing project
This project was created on 09/24/2021 and last updated 5 年前.
Description
Here is my camera setup for taking time lapses of 3D prints with an added extra to make them more interesting. It uses three stepper motors controlled by a Raspberry PI Pico to adjust the lengths of the strings hanging the camera, this allows it to be moved around the 3D Printer. The steppers are mounted to my Creality Ender 3's enclosure. The steppers are controlled from an Octoprint plugin which moves to camera between each shot taken using Octolapse.
Details
Log In/Sign up to comment
Sign up with Github
OR
ekaggrat singh kalsi wrote 02/21/2022 at 10:05 • point
It would be better to use a microstepper for rotating the head . That would give a much smoother end result. Nice project though. It reminds me of a string based delta printer published some years ago on the reprap forum.
I designed some accessories for GoPro Hero 3 camera which you can 3D print.
Project Owner Contributor
3D Printed GoPro accessories
robert-mordzonRobert Mordzon
I lost a cap for my camera. In order to prevent the lens getting scratched, I made an interesting cap using Fusion 360 and 3D printer.
3D Printed Cover for Microsoft Web-camera
afganaskerliafganaskerli
Trying to understand how a microscope works. Learn to 3D print.
OpenFlexture Microscope
pauline-chevalinPauline Chevalin
CoreXY 3D Printer with a Belt to automatically eject part. eveything fit inside the frame so that it's easy to enclose it.
CubeXYBelted
nathannNathann
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "3D Printer Timelapse SkyCam", please tell us the reason.
Send message
Remove Member
