A Power Switch PCB was designed to mount the original GameCube power switch to, along with a JST header for connecting to the motherboard.
Then began its integration onto the motherboard standoffs. A 60mm exhaust fan was also added, but in the end a 50mm fan was decided on to save space. The 60mm fan would interfere with the USB header on the motherboard and make it nearly impossible to plug anything in.
A few modifications were also made to the bottom shell, adding cutouts for the front I/O and a much sturdier slot for the front panel to drop into.
