Further improved the faceplate PCB to include the USB hub on-board, so I do not need to rely on using a third party 4-port hub. Also removed two USB ports to add a switch for the GameCube controller USB adapter which allows external toggling between PC and Wii-U mode. Then combined the memory card slot covers and standoffs into one single mount for the board
RetroModder
