The schematics
10/01/2021 at 20:13 • 0 commentsThe first thing I did after dumping the ROMs (since I was very worried they could start to lose data due to UV exposure and age) was trying to trace the schematics for all the boards.
I started with the older "Rotor 2 4 fili" line interface board; I just went component-by-component, marking each pin I had traced to another component with a marker while writing the schematics on paper. Since I had two almost identical boards (they are a different revision, but have almost the same schematics and the component designators match), I just kept one with the component side up and one with the trace side up to speed up the process.
As I was getting to the end of the process, it dawned on me that the method I had used meant that I could have missed some traces (because I marked a pin as "traced" as soon as I reached another component instead of following every single trace); also, there's a couple of relays and coils that. being (almost) direct shorts, could have led to errors.
Since I had two boards and no phone to put them into (you either find complete phones or ones that have been "converted" and are missing all the mechanical parts), I decided to just strip the most beat up one of all the components:
Front ![]()
Back I then went trace-by-trace, marking each one of them with my trusty marker and cross checking with the schematics I had already drawn. After much tedious work, this is what I was left with:
(the red lines are all the missing traces/mistakes I found after redoing all the work with the stripped board)
I still need to redraw this in Eagle, but I put that off temporarily when I realized this board does not contain the stuff I'm interested in (data communication circuitry and/or the card reader interface)
I then went on to investigate the content of the big potted module at the bottom of the board, thinking it might contain something interesting (after all, why would they pot it otherwise?). After spending much time with paint thinner, boiling water and various razor blades (didn't take any photos of that, sorry), I was left with a bag of broken components
and most importantly a schematic:
Turns out the module is a transformer-based switching power supply, used to charge the battery. Knowing this, the most logical possibility left is that the modem circuitry is all in the mysterious IC on the CPU board.
A bit disappointed that I didn't find anything really useful for my purposes, and sick of tracing PCBs, I decided to went on to track the software part; more about that in the next log
The PCBs
10/01/2021 at 14:10 • 1 commentAs said in the previous log, I managed to get my hands on a bunch of PCBs from the Rotor 2.
Here's the whole lot:
Aside from some ceramic modules which were broken in shipping (the eBay seller crammed all the boards in a much smaller box than this, with almost no padding...), the boards appear to be complete and in good condition.
I had a good look at all the stuff I've got (and at all the eBay auctions I could find that included photos of the internals) and I've got to say that the phone is a lot more complex that I anticipated.
There are four boards inside each phone:
1) The "line interface" board:
As the name suggests, this contains all the circuitry that interfaces the phone to the phone line(s). The section on the left, with the LS356B, is the actual "phone" part of the device. The connector marked as "a" connects to the keypad and the hook switch, while the RJ45 connector plugs into the headset.
The green two-pin connector connects to the integrated 6V lead-acid battery, which is recharged from the line and is used to power all of the internal components. This is presumably done to provide the short bursts of high current needed to power the electromechanical components (remember, the phone is spec'd to draw a maximum of 30mA from the line); it's wired like a double-conversion UPS, with all of the phone always drawing power from the battery.
Connectors D and possibly C seem to be used to connect to the internal/external coin safe, to enable the phone to know if the safe is opened/removed or simply full.
Connector B is used, alongside a normal 40-pin ribbon connector, to link the line interface to the main board.
The black box marked "64357/A", which I initially suspected to be the data modem, is actually the buck converter that provides the 6.75V for the battery.
2) The main board
This board is housed on top of the mechanical section of the phone and interfaces both to the line interface (through the 40-pin connector on the right) and to the mechanical section itself (with the big connector on the right).
The actual CPU board plugs in with the two circled connectors, while the single white connector on the bottom is used for the configuration memory.
This board contains a bunch of 74-series logic and a number of ceramic modules (which I think are DC-DC converters)
3) The CPU board
As the name implies, the CPU board houses the microcontroller that runs all of the phone, an Hitachi HD6305Y2. Luckily for us, this variant of the MCU has no internal ROM and it exposes its address and data buses to the outside world; the code is stored in a 27C256 EPROM which plugs in the DIP socket on the right. I've already dumped the ROMs and I currently have two variants, one simply marked "Rotor 2" and the other "Rotor 2 + L.I. v1.11" (L.I. probably meaning "lettore interno", "internal [card] reader")
The chip on the left is however a bit of a mistery. It's got what seems like a valid National Semiconductor part number, but I can't find any information about it. I suspect this is the actual modem chip I can't find any digital circuitry on the line interface board complex enough to be a modem.
4) The "external RAM" board
This board, as the name implies, houses a battery-backed RAM chip used to store configuration data. Contrary to what it might seem, the big DIP chip visible in the picture is actually a 27C64 EPROM; the actual 2K x 8 RAM chip is housed under the ROM.(it's a really weird DIP socket with the pins that taper out, allowing you to house ANOTHER similar-sized chip under the socket).
There's also an Intersil ICL7665 chip used to monitor the battery voltage and alert the processor if it gets too low.
4) Mistery board
I have no idea what this board is used for; I also haven't been able to spot it in any of the pictures of the phone internals I found on the Internet.
It seems to plug into the line interface board using the connector on the bottom right, but again, I have no clue what it is supposed to be.
It also seems like I'm actually missing a board, specifically the one that is mounted in the middle of the mechanical section (I'd post a picture of what it looks like, but I only have photos from eBay auctions and I'm not sure if I can repost them here). Again, I know very little about this one; I suspect it MIGHT be the actual coin discriminator board.What about the "other variant" of the phone?
In the previous log, I mentioned that, when looking at all the boards I had, I discovered that there's actually another variant of the phone aside from the Rotor 1, 2 and 3 models.
Here's what I'm talking about:
This line interface is marked "Rotor O.V." (presumably on the line interface board.OverVoice) and it appears to be a new revision of the two-wire board, radically different from the other ones; It's much more integrated and dense packing a lot of functionality in the same space. (the missing chip near the white caps is another modem chip, this time marked URMET/ItalTel v7308; I noticed just now I mistakenly photographed the one board I removed the chip from)
In this one, the CPU board actually plugs on the line interface itself, using the three-row connector:
You can see two of the new CPU boards here, alongside an old one. The new board is equipped with a Z80-based microcontroller and a 32K x 8 SRAM; this puzzles me: why would they go with such a deep redesign of the whole line interface and CPU board a couple of years after the release of the Rotor 2 (note the sticker on the ROM saying 8/10/1992)? it just seems like a waste of money.
Again, I extracted the ROMs (only the DIP ones; I have to get a PLCC adapter) and there'll be more about those in the next logs (I have material for at least two/three more posts, one about schematics, one about the disassembly of the software, and one about the decapping of the mysterious modem chips, so expect updates in the following days)
Also, if there's anyone reading this that actually owns a Rotor (I doubt it, but it's worth a shot) and is willing to take some pictures of the missing board and the internal wiring, please contact me.
Introduction
09/29/2021 at 16:55 • 0 commentsReading through old Italian phreaking e-zines and websites (see https://www.autistici.org/hacking_e-zines/ for an archive and the s0ftproject website http://bfi.s0ftpj.org for their e-zine, BFi, which was even mentioned on Phrack), I was always fascinated by the Rotor, mainly because it put a stop to all known tricks to get free calls and at the same time introduced a whole load of new features to prevent new attacks (bi-directional data link to the phone exchange, electronic coin discriminator, magnetic strip-based prepaid phone cards).
Brief history of Italian public phones
From the '60s up until the end of the '80s, the public payphone in use pretty much everywhere was the Urmet U+I ("Urbane+Interurbane", Italian for "Local+Long distance"); this was a simple electromechanical payphone whose operation was based on a solenoid and a series of microswitches. While there were some tricks put in place to prevent tampering (like subtle modifications to the lines they worked on to prevent people from simply hooking their own lineman's set to them), over the years a number of hacks, both electrical and mechanical, were discovered. While I can't say for certain which of them worked and which were fake, it's pretty clear that the phones were far from unhackable.
In the '80s, some of the old U+I were replaced with an improved model, the Urmet G+M ("Gettone+Moneta", "Token+Coin"), which as far as I know still worked in a very similar way, at least in regard to the way it interfaced with the phone line. The main differences were three coin/token slots instead of one (allowing the usage of coins alongside the usual tokens, as the name implied), a series of buttons to allow the user to input the number to dial (it still used pulse dialing, though, as all phones up to the Digito did) and a display to show the remaining credit; I suspect they had to add some kind of MCU to keep track of the different coin values anyway so they threw in the display just as a bonus.
By the end of the decade, however, it was pretty clear that these phones were pretty much obsolete. They had limited functionality, known flaws, and they fact that they stored quite a lot of coins meant that they were a popular target for thieves. To mitigate those issues, SIP (the Italian phone company at the time) commissioned IPM a new payphone; the initial plan was to create three new models, one for use with coins and tokens, one for use with the new phone cards (more on that later) and one for use with credit cards, but then they changed their mind (probably because they realized it meant building close to 3x the number of phones), and all the features were merged in a single new phone, the Rotor.
The Rotor
The phone itself is quite a feat of engineering. Weighing in at 32 Kg (approx. 71 pounds) of cast iron and fitted with an Abloy disc detainer core, it was quite resistant to brute force attacks. The mechanical coin acceptor was improved from the previous phones, with features such as an S-shaped tube at the beginning of the coin path (to prevent people from poking at the internals), a shutter with a blade (to prevent the old "coin on a string" trick), an electronic coin discriminator able to measure size, weight and metallic composition (the last one probably using inductive sensing) and a 20-pocket rotor (giving the phone its name) used to store coins until the end of the call.
On the electronics side, aside from a microcontroller which runs the entire device, it was equipped with a modem/transceiver enabling bi-directional data transfer between the payphone and the exchange using the HDLC protocol; this was used both for signalling purposes (it enabled the phones to alert the phone company of things like faults/tamper attempts/coin safe full) and to check the validity of phone cards and credit cards. It also offered some sort of remote configuration option.
(all the info here is either from the e-zines mentioned before or the Spaghetti Phreakers Cookbook, which can be found at https://archive.org/stream/SpaghettiPhreakersCookbook/Spaghetti%20phreakers%20cookbook_djvu.txt)
Variants
There seem to be three different variants of the phone (spoiler: there's actually a forth one I discovered only after looking at the PCBs; more on that in the next project logs).
- Rotor I (also known as "2F", "two wires") : the original model, released at the end of the '80s. This was AFAIK mostly found in public places like airports, stations, shops and bars, and is the only Rotor that can work on a normal "public phone type" two wire line. This made it a drop-in replacement for the old U+I and G+M phones.
- Rotor 2 (also known as "4F", "four wires"): an updated model released some time after the first one. Almost identical to the Rotor I on the outside, it was used in outdoor phone booths and could only work on a special line with two twisted pairs (one for data, one for voice). These four-wire lines could not be used with standard phones (again, to prevent people from simply hooking to them with their own handsets)
- Rotor 3: a model released towards the end of the '90s which did not have a coin acceptor (they were card only); these are physically smaller and also rarer. They were pretty soon replaced by the new Digito phones, but that's a whole another story.
All models have data communication capabilities (on the two wire models this is achieved using out-of-band "overvoice" signalling) and can be equipped with a card reader.
The "public phone type" line
As mentioned before, all payphones since the '60s worked on special lines. While there's pretty much no information on the four wire lines, the older style two-wire public phone line is pretty well documented since it remained unchanged even when the Rotor was introduced (again, to allow the Rotor I to be a drop-in replacement). This might not be all that useful, but since the only information I found on this was in Italian, I figured I'd summarize it here anyway.
This type of line doesn't differ much from a standard home phone line, apart from some extra signals that are added in order to make the payphones work (I suspect this was at this point a simple a software configuration change on the phone exchange side). This was especially convenient because it allowed the owners of bars and shops to request the installation of a payphone and all the phone company had to do was to attach the phone to the wall and just plug it into the existing phone line (they could even be equipped with a ringer and used to answer phone calls!), without the need for additional cabling.
There are two main differences from a standard home line:
- Every time the exchange counts a unit (phone calls were billed based on units called "scatti", whose cost was fixed and equal to the cost of a phone token; different types of calls made the exchange count up at different speeds), the line polarity is flipped. In the electromechanical phones this triggered the internal solenoid, which in turn made a token drop into the phones' safe.
- When the polarity is inverted and after the token has been successfully dropped in the safe, the phone opens the line for 50-60 ms. In the electromechanical phones this was achieved with a microswitch triggered by the token itself. If the exchange senses this pulse, the line polarity returns to normal. Instead, if the the line stays open for longer (this happened in the old phones if there were no tokens left), the exchange terminates the call; same thing happens if the exchange doesn't sense any opening of the line.
Because of this, a payphone can actually be made to work on a standard home line if you manage to get your hands on one; it just won't collect any coins you put in, because it will never see any polarity reversal on a standard line. The only catch is that, even with the Rotor, they are only capable of pulse dial, so they will not play nice with VoIP lines (fun fact: the phone itself consumes a maximum current of 30 mA, so it can actually be used with a VoIP modem)
Magnetic phone cards
This is one of the parts I found most interesting; to mitigate token/coin theft, SIP introduced alongside the Rotor (a card reader for the G+M was actually made, but I've seen very few pictures of it and I suspect it was more of a prototype for the whole system than anything else) the new magnetic strip-based, single-use, prepaid phone cards.
The cards looked like this:
Note that these don't follow the ISO 7810 standard for credit cards, both because of their shape (the corner gets cut off by the phone after the first use) and of their thickness (they're thinner because they need to be flexible).
Many phreakers over the years tried to decode the information stored on these with a bunch of different methods (magnetic field viewer strips, readers build with cassette tape heads, even a kids' toy hacked to output the resulting audio signal to a PC), but as far as I know it wasn't until 2007, with the Magneto project (http://www.radio.eptousa.altervista.org/progetti/magneto/ or BFi-dev-04 on the s0ftpj site) that somebody actually managed to get usable data off the card. Reading the cards, however, was only the beginning: nobody has been able to figure out what most of the data stored of the cards actually means; I hope the insides of the phone will be able to shed some light on the mistery.
The things we know about the cards are:
- Data is stored on two tracks, which carry the exact same signals (this is done to reduce interference).
- Data is encoded with what the guys from the Magneto project call "pseudo-ternary modulation": a peak (positive or negative) represents a 0, whereas 0 volts represents a 1; if the system needs to encode two (or more) 0s in a row, the polarity is reversed with each peak.
- Not all binary values can be encoded: the system doesn't allow for more than two 1s next to each other. In all, there's 11 possible bit values (0b1101 could be encoded but is not used)
- The remaining credit is stored on the card at the end of the data portion, HOWEVER the phones' firmware was quickly updated to ignore the stored value and just ask the phone exchange (using the data link) the remaining credit associated to the inserted card.
- The phone does send back the updated credit to the phone company (I'm not sure if this happens at the end of the call or after each "scatto") AND it still updates the credit value on the card (maybe to detect fraud attempts?)
A more detailed description of the cards' data band structure is available on the Magneto project website (also in Italian), but again, it's mostly about how they got the data off the card than what it means (apart from the section containing the remaining credit, which is well understood but also useless)
What's next?
These phones have become kind of a collectors' item, so their prices are pretty outrageous (and the fact that they weigh 71 lbs certainly doesn't make shipping cheap). Luckily for us, these so called collectors also like to actually USE their phones and, as I mentioned before, only the Rotor I can be used on a standard line; the Rotor 2 will refuse to work on a normal line (putting out error codes like "no communication with the exchange"), so a "mod" was developed to make them usable again. The thing is, the mod basically consists in stripping all but the keypad and headset from the phone, so there's a lot of old Rotor 2 PCBs which are basically useless. So, I was able to get a bunch of these for really cheap (like 25-30€ for a bunch of them) to play with them. I've already dumped the ROMs and traced parts of the schematic, so expect updates in the following days.
Edit 18/10/2021: corrected some of the information about the G+M. It seems like it is a little smarter than I thought and that it is indeed equipped with some kind of microcontroller. I've never seen the inside of one of those, but I strongly suspect they put a MCU in just to handle the fact that coins could pay for more than a single "scatto" and not much more than that (I seriously doubt they had electronic coin validation or data communication).
Also, i managed to find other pictures of the blue "prototype" card reader; I still think they were more of a prototype than anything else (there are some references online to some kind of "pilot phone booth" in Rome that was equipped with one of these). I cannot post pictures here because the only photos I found are from an eBay auction.
